by zaria123 » Tue 09.12.2008, 20:39
Hopefully you guys have a tip to get the wheel off?
It's going away tomorrow to be retrimmed in matching leather to the seats. Horn button is out, nut and washer off, but I have pulled, hauled and it won't budge.
Any ideas?
Alan
zaria123
- Tinkerer
by MattDon » Tue 09.12.2008, 20:49
stupid question but have you removed the 6 bolts fixing it to the hub? that done it should come off easily. might need to use penatraing oil on some of the screws (allan heads), the ones in my brg came off easily, but the ones in the steel blue are so stiff theyre rounding off
also check
this from the upgrades section.
please use email for contact
MattDon
by abmunro » Tue 09.12.2008, 21:24
I went round to a local garage and asked them to use a bearing puller to take mine off.
abmunro
by zaria123 » Tue 09.12.2008, 21:28
Thanks for that, steering wheel now off!
When I'd taken the horn button out I hadn't taken the foam gasket off, which then revealed the Allen screws - two of which were holding the horn ring, and four more behind it!
Thanks for the fast response.
Alan
zaria123
- Tinkerer
by MattDon » Tue 09.12.2008, 21:51
glad it went well.
yehy i helped someone
(what a refreshing change)
MattDon
Return to Chassis & Steering
