power steering pipe
power steering pipe
Postby tobyholland » Thu 17.10.2013, 20:30
Hi All
Just a quick question, the power steering pipe that goes from the reserve filler to the pump via the wheel arch drivers side, This has a couple of metal pipe in the run,if this pipe failed could it be changed for all rubber pipe
Thanks in advance
Toby :gathering:
a lotus is for life ,not just Christmas
tobyholland
Re: power steering pipe
Postby Fredjohn » Thu 17.10.2013, 21:03
This pipe is a low pressure pipe, so my guess would be yes, so long as it doesn't collapse. But I am not an engineer, so not sure if there aren't other issues.
However, see this thread too: viewtopic.php?f=8&t=21672&p=285825#p28582
Cliff got one made so they may have kept the template. There may be a case for getting a group buy going. I need a new one, although it hasn't failed yet. And Powersteering store are only about 5 miles from where I live.
Postby mitreklov » Tue 12.11.2013, 13:58
I think SJSportscars have reproduced this and other PAS parts that had been obsolete. They are listed on the their website.
Not cheap though.
In-between Elans right now
mitreklov
Postby Rambo » Tue 12.11.2013, 20:43
Have you tried AndyJ or Stef for a 2nd hand one ?
Return to Chassis & Steering
