by ShaunM » Sun 07.12.2014, 18:43
I've looked on the parts guide, but can't find it. It loops underneath the bottom radiator coolant hose then up next to the cam belt as can be seen in the picture (solid metal pipe in foreground. It is solid metal with rubber hoses at both end.
I noticed today that the rubber mount on the clamp that holds it in place (center of picture) is perished and is not holding it tightly, so wanted to get the rubber gasket for it to stop it rattling around. I'm thinking any rubber pipe of a suitable size would do the trick, as it's only to hold the pipe in place.
ShaunM on Sun 07.12.2014, 19:12, edited 1 time in total.
ShaunM
by dapinky » Sun 07.12.2014, 19:06
Ah, that'll be the low pressure power steering pipe, then......
- LEC Administrator
by ShaunM » Sun 07.12.2014, 19:14
ShaunM
Return to Chassis & Steering
