by Ted » Thu 11.12.2014, 19:00
Hi,
My PAS belt slips when fully steering.
When I fully turn the steering wheel, the PAS pulley stops turning and so the belt slips.
What could it be? PAS? Fluid? Pressure Valve?
Many thanks
Ted
- Tinkerer
by muley » Thu 11.12.2014, 20:05
Hi sorry to hear you are having a problem.
The belt drives the pump so if it is slipping it might be worth tightening the belt to see if that improves matters.
JIm
by Simon_P » Thu 11.12.2014, 20:29
Ted wrote:AS belt slips when fully steering.
There is a wire that goes to the underneath of the PAS pump. Make sure it is connected - It actuates a valve that prevents excessive pressure at full lock.
Return to Chassis & Steering
