Steering Play
Steering Play
Postby Simon_P » Mon 23.03.2015, 14:08
Hi All,
I have play in the steering rack in the straight ahead position. I've tried adjusting it out but the rack binds if I remove the play.
Does anyone know of a good rebuilder, or have a spare SE rack that isn't worn in the straight ahead position, or even one of the S2 racks bought from the aftersales a couple of years ago.
Thanks,
Simon
Re: Steering Play
Postby Simon_P » Tue 24.03.2015, 21:54
Reading another excellent article by Dave Pink on changing the steering rack.
Do I actually need to remove the raft? I have access to a lift.
Thanks,
Simon
Re: Steering Play
Postby andy b » Wed 25.03.2015, 20:46
I have just taken apart a crashed car there is a uj joint connected to the rack are you convinced it is the rack not the uj you would not notice it when turning but it would wander in the straight ahead position. I seem to recall i had a similar problem years ago with my excel and it was the steering uj just a thought.
andy b
If you can't fix it with a hammer it's electrical.
élan back on the road
andy b
Re: Steering Play
Postby Simon_P » Thu 26.03.2015, 00:54
Hi Andy,
I checked the UJ and it is good. Adjusted the play out of the rack, then it was tight either side of straight - pretty sure it is the rack.
Return to Chassis & Steering
