dapinky wrote:Yep - like Phil says, force the taper into the hub arm (sometimes it can be done with a piece of 4" x 2" timber, but a jack is ideal) - it may be that you have to actually lift the car to get enough grip, but the tequnique has never let me down.
As for the lock nuts on the actual arm, they can be cut (nearly) through with an angle grinder, dremmel or hacksaw, and then split with a cold chisel. Obviously, you will need new half-nuts, but they are cheap and easily availlable.... support the arm under the nut with a suitable pile of bricks/timber before you smack the cold chisel to avoid damage to the arm.
The combination of heat from cutting and impact from the chisel should shift it quite easily.
Now for the fun bit....
Rambo wrote:Slightly off topic and absolutely no help to you Phil but I am very impressed with the state of your front wishbones and everything else metallic
