Plus 2 Signature wheel on M100?
Postby sideways » Wed 29.08.2018, 20:28
I searched, honest.
Has anyone swapped the M100 stereing wheel with one from a Plus 2 and if so, is it do-able or should I go the Momo etc route?
Plus 2 wheel is 15" diameter, no idea about the spline/boss. knobbly bits involved to do this swap.
sideways at speed
Delta BC Canada
sideways
Re: Plus 2 Signature wheel on M100?
Postby lotusflasherman » Wed 29.08.2018, 20:52
I have a Plus 2S and 3 M100's and my question is "Why would you want to? " :banghead:
Postby Rambo » Wed 29.08.2018, 20:57
Yes, why ? I can understand retro fitting a Nardi, but a +2 wheel :?
PS and when did you get the 3rd M100 Phil ? :poke:
Postby Brit-Car-Nut » Wed 29.08.2018, 20:58
Being in Canada, he probably has a FED Airbag wheel which is an insult to sports cars.
Didn't phil buy a wreck recently?
Postby sideways » Wed 29.08.2018, 22:09
Brit-Car-Nut wrote:Being in Canada, he probably has a FED Airbag wheel which is an insult to sports cars.
Indeed I do and I have a Plus 2 siggy wheel lying around, maybe should just sell it and put a Nardi, Momo or whatever the flavour is this month.
sideways at speed
Delta BC Canada
sideways
Postby lotusflasherman » Wed 29.08.2018, 22:37
Ahhh... that explains it. The UK M100 SE steering wheel is nicer to use on a long drive than a Plus2 so if you are OK to lose the airbag, fitting one of those would be an easy conversion.
Postby Brit-Car-Nut » Wed 29.08.2018, 22:54
Unfortunately, adapter hubs for the Nardy, Momo or others that match the M100 FED spine are few and far between.
Then, you have to decide what to do about the clock spring and getting a connection for the horn button (without cutting the harness up).
You CAN install a UK wheel as the hub DOES fit the FED column. Drill the proper hole for the horn brush and you are good to go - except the FED wheel is basically the same OD as the UK wheel, so except for the aesthetic look, there is no improvement on steering.
Postby theelanman » Thu 30.08.2018, 12:59
just a thought
the chapman signature wheel on the +2 is about £600~£800 in good condition......and if you can find one
the boss is also too small so you'd have to butcher it.......
this would then make it worth nothing........
Postby Rambo » Thu 30.08.2018, 17:17
Isn't that Fed. steering wheel just the ugliest ever ? :shock:
Postby Elanlover » Thu 30.08.2018, 17:44
Rambo wrote:Isn't that Fed. steering wheel just the ugliest ever ? :shock:
Yes. :banghead:
Return to Chassis & Steering
