What is this? Forgot what this does - not a Sten Gun!
Postby AJSGSE1990 » Thu 20.08.2026, 06:52
Sorry about this, I now it's dumb not to take 1000 pictures when dismantling a car, and I should have done better. For the life of me I cannot remember where this goes?
Google Image search considers this is a:
Tubular and flat-steel welded shoulder stock / buttplate assembly designed to fit the rear socket housing of a STEN Mk II or Mk III receiver.
Thanks!
AJSGSE1990
Re: What is this? Forgot what this does - not a Sten Gun!
Postby KenS » Thu 20.08.2026, 09:55
Hi, its a 'bracing strut, underframe to longeron', either C100A0217F (LH) or C100A0216F (RH). Very easy to forget to fully tighten the top bolt resulting in a clonk when braking :oops:
S2 M100 NMY #285
N/A 2010 Evora
KenS
Postby dapinky » Thu 20.08.2026, 10:02
Edited to remove the same stuff that Ken beat me to posting!
Postby KenS » Thu 20.08.2026, 11:12
Ah, but Dave, I bet you had worked out if it was a left or right!
S2 M100 NMY #285
N/A 2010 Evora
KenS
Postby AJSGSE1990 » Thu 20.08.2026, 11:49
KenS wrote:Hi, its a 'bracing strut, underframe to longeron', either C100A0217F (LH) or C100A0216F (RH). Very easy to forget to fully tighten the top bolt resulting in a clonk when braking :oops:
Thank you very much, I was going crazy trying to find in the manual, I was convinced it went somewhere in the rear. Fnarr fnarr...
AJSGSE1990
Postby dapinky » Thu 20.08.2026, 16:28
KenS wrote:Ah, but Dave, I bet you had worked out if it was a left or right!
Well, I didn't get that far as by the time I'd got the right page from the parts book, I didn't refer back to the photo...... my initial explanation was that is goes from the raft to the chassis, and wanted to add the pictures to make it easier to visualise...... it is one of those parts that can easily be confusing as to proper location...... especially as when rebuilding the suspension, it looks 'complete' before it is bolted in.
Anyway, I would expect that both sides would be done (although that is an assumption) as this is a very thorough rebuild project.
Return to Chassis & Steering
