Noisy power steering
Postby Capman » Wed 07.06.2006, 22:09
Hi guys, Just purchased the car and can't help but feel that the power steering shouldn't make the 'hissing' noise it does as i turn the wheel. it appears to be coming from the steering column.
Any Ideas?
Elan SE 66k miles
Capman
Postby Andy_J » Wed 07.06.2006, 22:39
Hissing from the power steering is pretty normal for an Elan. IF the fluid is topped up and the weight of the steering feels fine, I don't think it you should worry
90H BRG SE 48,000 Miles
Andy_J
Postby M100 TWO » Wed 07.06.2006, 22:39
capman they all make a hissing noise on full lock nothing to worry about
john
M100 TWO
Postby Capman » Wed 07.06.2006, 22:54
Andy, John, thank you for the promp responce and for setting my mind at rest.
True gentlemen.
Regards,
Craig. :D
Elan SE 66k miles
Capman
Postby WillB » Thu 08.06.2006, 14:06
In fact if they don't make a hissing noise on full lock there's probably something up with your power steering!
WillB
Postby dkellis » Wed 14.06.2006, 20:16
Fyi, I recall reading a post on another forum here on LEC from someone who worked on his steering, topped up and bled the power steering fluid, and discovered that the hiss had gone.
Look for the keyword "snakes" in the subject line, as I recall.
PS: Yes, my steering hisses too and No I haven't done anything about it. It's 'way down the list.
dkellis
Postby Capman » Thu 15.06.2006, 19:28
Thanks for the feedback everybody. I'll let you know if i ever manage to tame the snakes.
Elan SE 66k miles
Capman
Return to Chassis & Steering
