Groaning bag of snakes steering
Postby Kjeld » Thu 21.12.2006, 04:44
I remember my first test drive in my Elan, pulling out of the drive way and hearing the hissing sound from the steering. "What the h*ll is that?". Like all Elaners, I became accustomed. The image of a bag of snakes under the hood hissing as I turn, is pretty cute too.
But it seems the bag of snakes is changing it's tune, as it were. The hissing has become a distinct groan, becoming louder the more the wheel is turned.
Is this a pump issue? Steering rack? 70k on the clock.
Ready to sell...... I think.
Kjeld
Postby Ekapol » Thu 21.12.2006, 10:15
Might be too obvious. So little I know. Did you check the fluid level? I topped it up recently.
Ekapol
Postby Kjeld » Fri 22.12.2006, 04:17
Fluid level, I wish. Thanks though Ekapol.
Can anyone tell me what the symptoms are for a failing pump?
Kjeld
Postby gmacz » Fri 22.12.2006, 22:38
Is it working harder to compensate for any seized joints.The one at the bottom of the steering column comes to mind.It might be fighting against these joints and the increasing groaning noise is the joint getting tighter and tighter.Yours Gmacz
The NaeLan Gives You Nae Trouble.
gmacz
Postby gmacz » Fri 22.12.2006, 22:39
gmacz
Return to Chassis & Steering
