by surfboardfiller » Mon 10.08.2009, 12:04
Has anyone had experience with a data recovery company in Britain.
I have a 5 year old HDD full of photos and important documents (Uni PHD etc).
Sadly there is no back up for this disk. It functions but some key files have been orphaned and I suspect a Memory failer has lead to the TOC or MBR to be damaged. I have installed a new HDD but Windows doesn't read any data on the old HDD and thinks it's un formatted.
surfboardfiller
by al » Mon 10.08.2009, 16:28
First thing: leave it the hell alone - don't get running any 'recovery' software on there yet.
Data recovery companies exist and they'll probably get back most of your stuff, but it's gonna cost you.
Based on you saying that the drive hasn't failed mechanically, personally, I'd be tempted to:
- image the drive somewhere, either to a file or block by block onto another identical drive (e.g dd).
[better would be two images so you can try various things, and roll back to try something else without going back to the original drive - you don't need a mechanical failure on top of everything else, and at least this way if all else fails you can send the original drive off to the experts]
- put the original drive away somewhere far far away from your fingers and temptations
- try the various recovery software on the drive image / target drives
- if applicable, make offerings to the gods of your choosing
- hopefully get your data back.
Depending on the filesystem type and size of the drive your mileage may vary.
I can probably help you with the above if you decide that's what you want to do, otherwise expect to spend between a couple of hundred and a grand to get the drive recovered professionally depending on how much manual intervention is required by the recovery guy.
a.
al
- LEC Bit Basher
by surfboardfiller » Mon 10.08.2009, 16:54
Yes please, it's Halas. I rebuilt her machine and it's fine now, but the data was more important than the box.
Could windows checkdisk have dammaged the data further by trying to auto recover files?
After I installed win XP on the new disk, I installed the old disk to see if I could copy the data off. I booted the machine and turned away for a few secconds. When I turned back windows had detected the old disk. I had 1 seccond to press a specified key to stop it but not long enough it automatically ran checkdisk
I was not happy about this to say the least, but that's windows.
But I though switching the machine off may dammage the disk further.
surfboardfiller
by lotos » Mon 10.08.2009, 17:03
Data recovery companies are cheap these days - I've seen prices like $150, $129, even down to $69-79, and you only pay when they recover the data.
That said, have you tried throwing it into an external USB enclosure and seeing if you can access it as a 2nd drive in a system?
lotos
by al » Mon 10.08.2009, 17:20
surfboardfiller wrote:Yes please, it's Halas. I rebuilt her machine and it's fine now, but the data was more important than the box.
>_< yep, that's exactly the situation I was trying to get you to avoid.
If things really are as cheap as Lotos says, then maybe that's your best bet, but whatever you do don't plug it in again USB enclosure or otherwise.
You're still welcome to bring it over and I'll see if I can help, but I can't make any promises. I'm out of the country until Sunday night, but you can pop around next week if that's any good ?
al
- LEC Bit Basher
by surfboardfiller » Mon 10.08.2009, 17:43
Thanks Al, I'll pop over when you are back.
Cheers,
surfboardfiller
by RayD » Tue 25.08.2009, 21:20
How did you go on with the hard drive Phil?
- Forum Member
by RayD » Tue 22.09.2009, 19:54
This is a bit of a long shot ... does anyone have the recovery discs for a Packard Bell Easy Note B3312
- Forum Member
by lotos » Tue 22.09.2009, 20:20
RayD wrote:This is a bit of a long shot ... does anyone have the recovery discs for a Packard Bell Easy Note B3312
I've downloaded restore/recovery discs via torrent, there aren't a ton of options but you may get lucky checking that route out.
lotos
by RayD » Tue 22.09.2009, 22:46
Thanks Randy,
Which of the ones on this
site is most likely to match ...
P/N PB21M02301
S/N 598706780239
MID 1036787and ... presumably I need to download a programme from elswhere in order to download the torrent file? ... if you could recommend one.
- Forum Member
by lotos » Tue 22.09.2009, 23:10
What operating system + version do you have?
lotos
by RayD » Wed 23.09.2009, 09:16
On my desktop computer ... XP Pro Version 2002 + SP2 ( This is the one I'll use for downloading the files)
On the Packard Bell lap top ... XP Home Edition Version 2002 + SP2
- Forum Member
by saska » Wed 23.09.2009, 09:44
Could be wrong but i don't think PB provided recovery discs -- there should be a hidden recovery partition which is accessed via F11 at startup.
Tony
adw (at) saska.co.uk
saska
by RayD » Wed 23.09.2009, 14:54
Your'e not wrong Tony,
When the original owner bought the machine PCWorld relied on customers to make their own recovery discs.
While pressing F11 at start up accesses the recovery system it asks for the discs that were never made.
Apparently Packard Bell will supply them for £45...
- Forum Member
by lotos » Wed 23.09.2009, 15:59
RayD wrote:On my desktop computer ... XP Pro Version 2002 + SP2 ( This is the one I'll use for downloading the files)
Any specific reason to use a Packard Bell restore disc, or do you simply want a new Windows install? I would sya, unless you want all the cr@p and bu!!$sh!t they install on new computers, just download an XP Pro disc, and an XP Home disc, reformat and restore with that (using your legit Windows Key from the original Windows installs, perfectly and completely legal so no worries), and have a new computer install without the bloat.
If that sounds okay, let me know and I'll track down good torrents for ya.
lotos
by RayD » Wed 23.09.2009, 18:29
Thanks Randy,
It’s quite slow ... I wanted to see what it was like at factory settings and decide if it was worthy of buying more memory.
(Requires a 512 MB 200-pin, non-ECC PC2700 DDR SO-DIMM)
But ... an XP Home disc sounds more appealing ... if only to get rid of all the rubbish.
- Forum Member
by RayD » Sun 27.09.2009, 16:10
You have an email Randy,
- Forum Member
by RayD » Sat 24.10.2009, 18:04
A couple of weeks ago with Randy’s help I downloaded XP Home plus SP3 and put it on a disc.
Is it practical to get the drivers from the laptop onto a memory stick prior to reformatting then re-install them afterwards?
If so, which will I need, and where will they be ....?
Thanks Ray.
RayD on Sun 25.10.2009, 16:09, edited 1 time in total.
- Forum Member
