zipped files
zipped files
Postby whippit » Tue 10.11.2009, 22:00
hi all
could i ask those in the know how i view zipped files
iv'e loaded winzip,
if i open enything on elanscan it display's a load of numbers and letters,
some time it tells me the file is not supported as well,
my laptop running vista,
also does any one know how to change the latancy timer on vista,
if i run elanscan and get a bad echo, geoff advised me to change it to 1 ms but ive failed to even get close to finding it anywhere,
thanks for any advice,
whippit
Re: zipped files
Postby ailwyn » Tue 10.11.2009, 22:48
Open the zip file with winzip, then extract the contents to a folder.
You should only be opening .ecu files (which are probably contained within the zip and need to be extracted) with ElanScan.
I'm not 100% on where to set the latency, but most likely Start > Control Panel > System > Hardware > Device Manager > Look for the adapter in the list > right click > properties. If you're not sure might be worth trying to acquire the assistance of a spotty teenager.
Re: zipped files
Postby whippit » Wed 11.11.2009, 00:35
i looked in in the device manager,
found display adapters and network adapters, but nothing saying latancy in the properties page ,
i opened elanscan with winzip put the fill in a folder unzipped it and found a load of computer wording in a box ,
bloody computers drive me crazy,
whippit
Re: zipped files
Postby GeoffSmith » Wed 11.11.2009, 01:37
Not sure of Vista Tim, but read the XP write up in Wiki help as it should be similar - you need to look under Ports (COM & LPT) or similar and not display or network adapters.
Re: zipped files
Postby rizla » Sun 24.01.2010, 18:11
Have you tired right mouse clicking and selecting unzip? If not there are a myriad of "unzipping" solutions on the net, winzip is a good example. Just make sure you note where the files are unzipping to.
He's back.....and it's about time!
rizla
