Laptop won`t start up ?
Postby Monty » Tue 28.02.2006, 20:06
I`ve bought a cheap 2nd hand laptop and was working fine when i got it but there was a button missing on the mouse pad which had been pushed inside so out came the screwdriver and i glued the little sucker back in. I also change a couple of things in MS config startup but now the comp won`t restart and says something like:-
windows could not start file missing or corrupt
\windows\system32\config\system
try using set up disk to repair
The only thing is i haven`t got the setup disk, i`ve tried starting up in safemode etc but no joy :roll: I`ve tried e.mailing the computer make but the e.mail is just bouncing back :?
Comp is
I-friend NC202i4
XP home edition and has the product key on the rear.
PC world are a waste of time as they can`t do anything without the recovery disk.
Is it possible that microsoft will send out the software since i have the product key?
Any help would be much appreciated
Jay
Re: Laptop won't start up ?
Postby Doug » Tue 28.02.2006, 20:42
Monty wrote:I also change a couple of things in MS config startup . . .
that'll teach ya . . . :lol:
sounds like you need a start-up disc
I might think you could get one from someone else but it'll have to be 'laptop oriented' I think instead of for a desktop.
Postby Gary » Tue 28.02.2006, 22:14
If you can get a copy of the XP Home CD then you can use that to repair it, but it will require some techy knowledge.
Best thing is to find some-one who knows about these things and get them to do it for you. I'm a long way away, but if you can get it to me (via Dico ??) then I'll have a shot at it for you. Unless you can find some-one closer
Postby Monty » Tue 28.02.2006, 23:57
Thanks for the offer Gary, there`s a small computer shop about 15 mins away i`ll have a word there 1st when i get time.
BTW this laptop only has a cd rom will this still play CD-R`s & CD-RW? :?
Postby Gary » Wed 01.03.2006, 12:01
Yep should do. It obviously won't write to them though
Postby TStevens » Wed 01.03.2006, 12:57
It will be able to play Finalised CD-R's but not RW's
TStevens
Postby Gary » Wed 01.03.2006, 15:17
Don't you mean it will be able to play all CD-Rs, but only finalised CD-RWs ??
Postby TStevens » Wed 01.03.2006, 18:13
Not all CDRom drives are capable of reading mutlisession CD's, and require CD-R's to be finalised. Most modern drives are ok with mutlisession though.
Re-writeable disks generally wont work in anything except a cd writing drive. There may now be some exceptions to this, but in my experience RW's would only work in a writeable drive, and even then some required the session to be finalised for that to work if you didnt have the same software that wrote the disk.
TStevens
Postby Gary » Wed 01.03.2006, 18:41
Yep what you says makes sense I've had no end of problems with CD-RW disks. Whereas DVD disks are much better. DVD-RW disks do what they say on the tin.
Postby Ashaman » Sat 04.03.2006, 05:18
When you say a button was missing, like it was pushed inside - like the result of a pretty good impact? A decent impact could cause a hard drive crash....
Strange to have a file missing, though it could be the result of something else (virus or whatever). You can purchase the installation media which is typically very cheap (since you already have a legitimate license).
Regarding the drive, most reasonably modern laptops use a standard format; you should be able to add a multiformat DVD recorder for $80 if you like.
Ashaman
Postby TStevens » Sat 04.03.2006, 12:44
I can provide media by post/donington if required.
TStevens
Postby Monty » Sat 04.03.2006, 20:13
Ashman,
It wasn`t the start button missing, it`s the left clicker for the touch pad, anyways i left it in and it was just a software problem but cost me £45 :shock: anyways i gets it home and i can`t connect to the internet says
can`t renew IP address
:roll: so took it back to the shop and he say`s it`s a i need to get intouch with ISP and told me to try a couple of things, so i thought i`d popped to Dico`s for a cuppa and guess what i get lumbered with errrrmmmm fixing there internet conection on there desktop and laptop (spent hours there :roll: ) so i eventually gets home, switch on comp and the dam thing won`t start up now :evil: now i don`t know if this was something to do with it being freezing outside and the comp stuck in the boot for hours :?
Tony
If u could provide the media at Donny that would be grand
