BRG 1991 H SE including parts for sale £3000 job lot - SOLD
Postby Denny » Mon 01.12.2014, 20:24
1991 H Elan SE with 89000 miles in BRG; completely standard. MOT until September 2015.
It is a good car but needs some TLC on the paintwork and a couple of mechanical bits but not much. The rear lower wishbone on the near side is slightly bent but it has always passed a MOT like this. I have a second hand wishbone with bushes ready to go on. I renewed the soft top and the majority of the seals in 2004 when I bought the car and they are still very good as the car is kept in a garage and only out when it's dry. Could do with A pillar seals but not to bad. All electrics work and the rear lights are very good as I fitted a new off-side unit in 2004.
Service history up to 81000 in 2003 and then self serviced by me since with semi-synthetic oil.
The engine sounds sweet and pulls very well. Gears are a little sloppy but all gears select ok. Handbrake is good and holds on a hill. Standard brakes are what you would expect.
Interior good with re trimmed leather before I bought it. No marks or cracks on the dash.
Close inspection will see gel coat cracks on the near side door and off side front wing typical of aging fibre glass and a few other minor chips & scrapes but car still looks good.
Aftermarket alarm/immobiliser with remote central locking all works ok.
I have been collecting a lot of spare parts over the years, some new and some second hand but have never got around to putting them on the car :oops:
I want to sell it as a job lot including the parts for £3000 NO OFFERS / BARGAIN! I'm not going to sell the parts separately at this time so don't ask.
Of the top of my head, here are some of the parts:-
New:-
Bob Brown rear hub conversion with bearings
Bob Brown stainless steel gear cables
AB motorsport gear cables & short shift
Gordon's fans.
Set of MSD ignition coils
LGM Roll Hoops with wind deflector
Standard front brake discs
Bob Brown rear brake refurb kit with anodised sliding pins
SJ Sports Cars rear caliper refurb kit
SJ Sports Cars stainless steel braided brake hoses
Oil Filter
Air Filter
Spark plugs
HT leads
OEM Aerial
Top door / window rubber seals (group buy)
Poly bushes for rear wishbones
Rear camber bolts
Elise rear light conversion panel by ChrisP - primed but not painted & delivery crate never opened
Cam belt kit including; belt, water pump, idler & tensioner - the correct kit. Last changed at 61000 according to the service book?
Front top wishbones (fed car but fit mine apparently)
Door handle esch by Wayne.
B post caps by Wayne (the old one are still intact and OK)
Second hand:-
Set of refurbished & powder coated rear wishbones
Set of Elise lights (not LED) & a spare M100 rear light wire harness to connect them
Rear bumper in BRG with a good bottom grill but needs repainting
Rear brake discs with bearings (decent)
Rear brake callipers (need refurbishing)
There will be other bits and pieces but above are the main ones.
I will post some pictures at the weekend.
I have enjoyed this car for the last 10 years but I've now lost interest.
Denny
Re: BRG 1991 H SE including parts for sale £3000 job lot
Postby fillpoke » Mon 01.12.2014, 21:06
Would I be able to come to see the car tomorrow ( Tue 2nd Dec) please? I'm in Hartlepool.
Thanks,
fillpoke
Re: BRG 1991 H SE including parts for sale £3000 job lot - S
Postby Denny » Tue 02.12.2014, 20:08
Sold to a good home and previous M100 owner.
Denny
Return to SOLD Cars
