lotusflasherman wrote:I worry about low mileage cars when the MOT History shows the mileage is lower in 2017 than it was in 2016, having done -258 miles that year ... driving backwards for a year maybe ..![]()
N752ESG
LOTUS ELAN
Colour Green
Fuel type Petrol
Date registered 11 April 1996
MOT valid until 16 May 2020
If you think the MOT expiry date or any of the vehicle details are wrong, contact DVSA.
Open All MOT history
Check mileage recorded at test, MOT expiry date, defects and advisories, and view test certificate
Date tested 17 May 2019 PASS
Mileage 67,265 miles
MOT test number 3144 8216 1691
Expiry date 16 May 2020
Repair as soon as possible (minor defects):
Front Outer Drive shaft joint constant velocity boot severely deteriorated (6.1.7 (g) (i))
Date tested 27 July 2018 PASS
Mileage 67,041 miles
MOT test number 4450 0458 5874
Expiry date 26 July 2019
Monitor and repair if necessary (advisories):
Parking brake lever defective but can be satisfactorily operated (1.1.6 (d))
Rear Brake pad(s) wearing thin (1.1.13 (a) (ii))
Vehicle structure is corroded but structural rigidity is not significantly reduced (6.1.1 (c) (i))
Exhaust has a minor leak of exhaust gases (6.1.2 (a))
Oil leak, but not excessive (8.4.1 (a) (i))
Offside Rear Tyre slightly damaged/cracking or perishing (5.2.3 (d) (i))
The MOT test changed on 20 May 2018
Defects are now categorised according to their severity – dangerous, major, and minor. Find out more
Date tested 31 May 2017 PASS
Mileage 66,471 miles
MOT test number 9288 3973 6782
Expiry date 5 June 2018
Advisory notice item(s)
Lower Body has slight corrosion (6.1.B.2)
Vehicle structure has slight corrosion (6.1.B.2)
front and rear suspensions corroded
Rear Brake pad(s) wearing thin (3.5.1g)
Oil leak ()
Exhaust has a minor leak of exhaust gases (7.1.2)
Date tested 6 June 2016 PASS
Mileage 66,729 miles
MOT test number
7596 0611 6593
Test location
View test location
Expiry date
5 June 2017
rear brake disc corroded
both rear tyres are cracking
Date tested 6 June 2016 FAIL
MOT test number 8671 3463 1780
Reason(s) for failure
Nearside Rear position lamp(s) not working (1.1.A.3b)
apollo996 wrote: So you think somebody has 'clocked' it 250 miles one year ?Very funny. I think its far more likely on the MOT in 2016 they misread the 1 as a 7. Mileage should of being recorded as 66129. I actually have all the MOT certificates from 2000 onward. I can assure you the mileage is genuine.
apollo996 wrote: Yes I have taken a few M100's apart over the years for spares but only because they were uneconomical to repair. I've driven Elan's for years as well so am a fan. It was never my intention to sell this car. I know I will struggle to find another as good but have other modern classics I use more often. Only having 2 seats is a real issue with a growing family and I need to trim my collection.
