Service Manual 'Section WB' P/N E100T0327J for Fed SIR?
Electronic and hardcopy, manuals, articles, books etc.
Postby donsladek » Sun 24.06.2007, 21:35
Anyone have the FED SIR (airbag) manual that could make a copy for me - or is it online somewhere?
My horns occasionally sound while turning or on bumps, and I'd like to know what precautions are needed before working on this.
PM me if you can help.
Thanks!
Don Sladek
Don Sladek
Calypso Red '91 #37594
donsladek
Postby Fubar1764 » Mon 25.06.2007, 03:52
Don, I removed the airbag and wheel in an attempt to fit an SE wheel (Monty's Pinky was the donor). I don't think you need to have the SIR manual in order to work on wheel.
That said, I'd definitely disconnect the battery just in case to prevent the airbag from deploying. The airbag is secured by four bolts in the back of the wheel. If memory serves, they're hex or star. Removing these 4 bolts will allow you to remove the airbag. The airbag will simply lift off the front of the wheel. When you loosen and then remove the bolt, you'll know what I mean.
Next, the airbag has a single lead which goes to a wiring harness. When you undo that harness, the airbag will be completely loose.
What's probably going on is that your horn buttons or wires are corroded. Replacing the wires should fix your problem. If you need me to remove my wheel and send you the pictures, I can do that. PM me.
Cheers!
Jack
-Your "Jack" of all trades
Fubar1764
Postby Doug » Mon 25.06.2007, 08:36
Don,
sounds like you have a bad horn switch! -- Ekapol made a thread about how to replace them here somewhere
yes, the bag is held by hex or star screws, but I remember tightening 2 of them that got a bit loose with just a simple flat screwdriver that fit right into the head
-D
Postby Fubar1764 » Mon 25.06.2007, 23:37
Also Don, the switches are the same as a Pontiac Firebird. I would imagine they're readily available from a Pontiac dealer if only you could find the right part number and a cooperative Pontiac dealer. Were I to guess, it's a "comes only with the _____ assembly," hence costing a gazillion dollars. The buttons are some of the shoddiest pieces of plastic you'll ever see. I think everyone would be interested in the Pontiac part number if you find it - I got my replacement part thanks to Nitroman's wrecked Elan. Good luck!
Fubar1764
Postby donsladek » Tue 26.06.2007, 04:16
Doug and Jack,
Thanks for your help, I'll give it a shot and see what I find under that POS cover!
Cheers,
Don Sladek
Don Sladek
donsladek
Return to Literature
