Front & rear suspension for sale from 16k elan
Postby m100sandra » Fri 10.05.2013, 16:51
As title, Full front and rear standard dampers for sale from my Elan which as only covered just over 16000 miles, Only reason they are for sale i have just fitted a full set of Nitrons, In good condition (as you would expect) with no leaks etc.
Price, i was thinking £150 + shipping
I seem to be having a problem with my PM's at the moment :? It was full i have deleted some messages, but i still have a new PM which isnt showing :?
Sandra
P.S. Ill try & take some pics if required.
m100sandra
Re: Front & rear suspension for sale from 16k elan
Postby RayD » Fri 10.05.2013, 21:53
Sandra,
I have also got one new message in the inbox that isn't showing ... it's been there for a while.
Postby m100sandra » Sat 11.05.2013, 10:18
RayD wrote:Sandra,
Wonder why :? my inbox is showing 80% full, frustrating :)
m100sandra
Postby DavidEJM » Sat 11.05.2013, 22:00
Hi Sandra
I might be interested, I will need to look at my pennies though.
PM me when you get it working
Oooooh shiney!
DavidEJM
Postby m100sandra » Sun 12.05.2013, 09:21
PM's now working :-)
m100sandra
Postby m100sandra » Mon 13.05.2013, 05:19
m100sandra
Postby Brit-Car-Nut » Mon 13.05.2013, 05:32
Possibly an explanation as to your uneven level: the r/h front shock/spring in your picture has the wrong colour code for a UK Turbo spring. Should be yellow, yellow, green. No red in the code.
That spring appears to be shorter (maybe stiffer) as it doesn't expand the shock as far as the other spring. That is just looking at your picture. Can't see if the top plate is installed, but the spring looks to be wound differently anyway.
Postby Brit-Car-Nut » Mon 13.05.2013, 12:55
The spring on the right appears to be a FED spring as they all appear have an extra red splash on the other side of the 3 colour code. It is probably a blue/yellow orange on that spring?...
Postby m100sandra » Mon 13.05.2013, 13:30
Brit-Car-Nut wrote:The spring on the right appears to be a FED spring as they all appear have an extra red splash on the other side of the 3 colour code. It is probably a blue/yelloow orange on that spring...
Just got my Son to check the Spring, both are the same, Green & Yellow down the entire spring(s) and both with one splash of red, Both measure the same length. Tbh when the car was in for the Nitrons fitting, they checked the ride height out and it was bang on as per manual.
I would have been really surprised if somthing had have been altered from new knowing how the one & only owner was with the Elan
Ill try and get a picture of the springs if i get the chance Today........
m100sandra
Postby m100sandra » Wed 15.05.2013, 15:12
A few more pics showing the correct colour codes better :-)
m100sandra
Postby DavidEJM » Thu 16.05.2013, 23:19
Hi Sandra, I've sent a PM
Oooooh shiney!
DavidEJM
Postby Piperman » Sat 29.06.2013, 06:17
Hi are these still available will they fit my 91 turbo derek aka piperman
Postby seaspider » Tue 17.03.2015, 15:53
Hi Sandra, are your shocks still available? I've a 91 LHD stock Elan.
seaspider
Return to Elan Parts for Sale (Used Parts For Sale)
