Saw your last post about availability, are there any FED 1499's left? Would love to grab one ASAP if available. Thanks!
RonR wrote:Hi Paddy,
Was the O2 reading taken with the engine nice & hot? I usually let the car idle until fans on before going for an MOT, it helps.
Did you use the method in the engine management manual, adjusting the CO Pot while using an exhaust gas analyser?
If that didn't get you below 3.5% then the 9930 will give you more adjustment range on the Pot. Lotus released this prom for exactly this purpose, so it SHOULD work.
The 1499 closed loop conversion should take the O2 readings much lower, but without a catalytic converter in the chain it wouldn't be as low as with one.
Over the next week or so I'm going to experiment with my spare MemCal to see if I can erase and re-program its original chip with a new prom image (after 32 years in a car it may or may not work!).
If it's a success I can offer to re-program your existing 9929 to 9930.
dapinky wrote:So, my thought process is this - can the OE pot be replaced with an aftermarket preset pot with a bigger range (or completely different range, except they all tend to go from 0 to whatever Ohms), or even with a fixed-value resistor to give lower emission values?
I understand that this is a very agricultural way to get to an arbitrary number, and the the electronics *should* be able to do it for us - but would it work????
Your 270 Ohm reading is the lowest resistance possible, as the CO Pot has a 270 Ohm fixed resistor in series with it (From the WIKI Backup HERE). The resistor is there to limit the current taken from the ECU's reference supply, so I wouldn't go changing it!
I made an adapter to plug the Memcal into my Eprom programmer. It was able to read the Memcal contents, but unfortunately the programmer can't write to the particular chip used in the Memcal. I may be able to make a modification to allow it to be written, but it may take some time to make the alterations.
However, I may have a solution: One of the guys I have been holding a board for hasn't been in contact since September despite emails etc, so I'm going to say he's dropped out. I could re-program this board to 9930 and 1499, so you could have either open or closed loop.
happylarry007 wrote:Hi I would like to purchase one of the upgrades (Everest) Please,
