New ECU add-on boards available - Form an orderly queue!
Re: New ECU add-on boards available - Form an orderly queue!
Postby Relevance » Sun 27.08.2023, 03:20
1. Geordie not sure which is best for me ,need some guidance
2. Blaster 1499 + Everest
3. Wortho 1499 + Everest
4. Roger D - TBD by PM
5. Relevance Unsure of Prom/will update + Everest
6.
7.
8.
9.
10. Simon_P Not in a hurry answers to follow but S2, 2 and Everest (I think)
Jake
1992 Silk Red Project
Relevance
Postby RonR » Tue 29.08.2023, 16:06
Wortho wrote:3. Wortho 1499 + Everest
Hi Wortho, You have a PM!
Postby Michael bluey » Wed 06.09.2023, 13:12
If you're interested in getting a board, please add your name to the list starting in Post 2 of this thread in the usual LEC manner, and don't forget to say if you require 1 or 2 images, the prom version, and whether Standard, Kilimanjaro or Everest. I'll follow up by PM to each member.
6. Michael bluey 9930 Everest has prom 10 on chip as well
7.
8.
9.
And what a gentleman Alan is for letting them be used!
Michael bluey
Postby Michael bluey » Wed 06.09.2023, 13:22
Ron
Can you add me to your list we spoke at castle Combe can I order a 9930 Everest chip has prom 10 on 9930 chip if this is needed I don’t know.
Michael Bluey
Michael bluey
Postby Blaster » Sun 10.09.2023, 17:08
I have fitted mine today after repairing the front roll bar drop link.
I did not want to try the boost while getting an unknown clunk.
Switched to everest and the boost gauge goes up to nearly full scale.
Thank you Ron.
Tony
1990 Lotus Elan SE 2009 Triumph Daytona 675SE
2012 KTM Freeride 350 2008 VW T5 4-Motion camper.
1995 Defender 300TDi 2012 Ducati Hypermotard
2018 AC Nitro 200 and Dudek Solo wing
Blaster
Postby Geordie » Tue 19.09.2023, 14:51
Hi all
Fitted mine yesterday ,changed from open loop to closed loop (thankfully wiring already there) using bosch 02 censor
All very straightforward once I removed and checked ECU ,took on short run ,worked a treat
Happy days
Thanks Ron
Geordie
Postby Luvmeadeadpedal » Wed 20.09.2023, 16:15
I am in for a federal 1499 chip
Luvmeadeadpedal
Postby RonR » Wed 20.09.2023, 21:24
A quick update on the status so far:
1. Geordie - Delivered
2. Blaster - Delivered
3. Wortho - Delivered
4. Roger D - Delivered
5. Simon_P - Delivered
6. Coops - Delivered (Chip only)
7. Relevance - Under way
8. Michael bluey - Under way
9. Luvmeadeadpedal - Under way
10.
Postby RichB » Fri 22.09.2023, 06:13
Ron,
I would be interested. 1499 + Everest, please.
Thank you!
RichB
Postby niall » Fri 22.09.2023, 20:49
[quote="RonR"]A quick update on the status so far:
10.
11. Niall-upgrade old Everest to closed loop when available please.
niall
Postby HJ2 » Sat 23.09.2023, 17:18
RonR wrote:Hey HJ, Does the "currently!" mean you're on the lookout for another M100?
Not currently no!
But hey... I still can't refuse a good group buy and support this fine piece of work!
10.HJ2 S2 Everest please, let me know how to sort payment!
Postby RichB » Fri 29.09.2023, 18:01
Now that I understand the usual LEC way ...
12. RichB -- 1499 and Everest, please, should you be able to do more than the original allotment.
RichB
Postby RonR » Fri 29.09.2023, 20:35
No problem Rich, I found enough original chips for 30 boards or so, you're on my list - board is built, programmed and waiting for a cable delivery to finish.
Postby britishsteel » Sun 01.10.2023, 02:05
13. Britishsteel 1499 + Everest
britishsteel
Postby RonR » Tue 17.10.2023, 11:18
Thought I'd give a small update on how things are going with these boards:
I have enough boards and chips for 20 or so more, and the prototype multi-switcher (different chip) is in my car ATM with no problems so far. :burnout:
7. Relevance - Delivered
8. Michael bluey - Delivered
9. Luvmeadeadpedal - Pending delivery (with USPS)
10.HJ2 S2 Everest please, Next up
11. Niall - Delivered
12. RichB - Pending delivery (with USPS)
13. Britishsteel - Delivered
Postby mattdovey » Fri 03.11.2023, 21:19
I've decided to convert the car over to closed loop this winter. So if you still have some available I'd like one please.
14 Matt Dovey 1499 + Everest
mattdovey
Postby RonR » Sat 04.11.2023, 18:36
No problem Matt, There are still some chips left in the bag!
I'll be in touch....
Postby Barrykearley » Sun 05.11.2023, 21:46
Please can I be added to the list please
S2 with AXMZ1523 written on the chip
Barrykearley
Postby Shortjedi » Sat 11.11.2023, 23:10
15 Steve Kent 1499 + Everest
Shortjedi
Postby White Elan Man » Sat 18.11.2023, 23:14
One for me please Ron, thanks.
I added Barry Kearley to the list before me
15 Barry Kearley
16 Steve Kent 1499 + Everest
17 Whiteelanman 1499 +Everest
White Elan Man
