Pump-to-filter fuel pipe
Postby RobertC » Wed 23.09.2026, 01:08
For anyone wanting to keep close to the original OEM spec I can make up new pre-formed nylon pump-to-filter fuel pipes. £30m each, plus P & P.
This is only the pipe itself, it does not include the end connectors.
I will insert end connectors if they are sent to me for an additional £15.
Please email me (RSAC@zoo.co.uk) as I don't frequently look at the forum.
N.B. For information --
I've found that it can be difficult to insert the end connectors.
If you are not familiar with inserting barbed pipe tails into nylon fuel pipes I would advise to practice a good few times on spare nylon pipe [8mm OD, 6mm ID] before attempting to insert into the pre-formed pipe.
You will need a heat gun, not of the flamed variety and preferably with a digital temperature setting ability, that can set to around 200°C-250°C.
Unless the insertion is done correctly, i.e. without twisting, there is a good likelihood that the pipe will distort, buckle or kink, making the pipe unusable in the process.
RobertC
