Front Brakes... A Modern Option (SOLD)
Postby Jamie N » Wed 13.09.2023, 13:45
I have these on my S2 and have 2 spare sets if anyone fancies an upgrade without spending a fortune. These are fairly recent Bosch calipers and perform
excellent, the difference when I fitted them to my Elan was profound, far sharper than the originals that I removed from it. A lot easier to service as well,
no more driving out stuck pins from the pads and very simple to remove the sliders, there is also more pad in contact with the disc than the originals, they also fit under 15s.
Comes with everything to fit, pads and flexi hoses and bolt on with the original Elan carrier bolts. No modifications required, you simply bolt them on, change the flexi hose,
bleed the brakes and that's it job done.
160 plus postage, or come to Fife and I'll fit them for you.
How the carrier sits....
Fit the disc and pads....
Fit the caliper, this picture shows how simple it is to change the pads, remove one 13mm bolt, pull out the caliper just enough to create a gap between the old pad and the piston
into which you put a flat blade and lever back the piston, swing the caliper up and remove the pads, it just doesn't get any easier than that.
Monaco S2 #406
Jamie N
Seal God
Re: Front Brakes... A Modern Option
Postby Geordie » Wed 13.09.2023, 13:52
Hi Jamie
I’m up for a set of those for my se turbo ,they sound a good equivalent to some of the other outrageously priced alternatives
Geordie
Geordie
Postby Tuga2112 » Wed 13.09.2023, 14:00
Geordie wrote:Hi Jamie
Geordie
if you travel to fife, you may as well get a set of seals and rear calipers from Jamie :wink:
by the time you finish your shopping list you'll have a 4 figure sum :lol: :lol: :lol:
but you gotta be mindfull this is fitted on a S2. with the 16 wheels instead of your SE's 15
Postby Geordie » Wed 13.09.2023, 14:27
I already have rear brake upgrade from Jamie (they work a treat) so I expect front upgrade will also be good ,,even if you put both costs together they are a fraction of the PNM or Willwoods for either set ,,as for the roof seals ,I received a set of A post seals (rubber) when I purchased the car ,simply can’t afford Jamie’s seals at the moment ,but not a priority ,concentrating on engine/gearbox and brakes this year maybe next year ,didn’t expect being a lotus owner to come cheap ,but I’m happy upto now
Geordie
Postby FunElan » Wed 13.09.2023, 15:10
Those of us in the colonies are awaiting the creation of a wiki post with the steps to recreate your "over the counter" rear brake upgrade :-D
FunElan
Postby woody » Wed 13.09.2023, 16:31
Hi Jamie,
I will have the other set of disc brakes, if they are still available.
Cheers,
Woody
woody
Postby woody » Wed 13.09.2023, 16:34
Sorry,
Delete that message, I thought they were rear brakes. I have Wilwoods fitted on the front.
Cheers,
Woody
woody
Postby chrism » Wed 13.09.2023, 20:57
Yes please Jamie N, I'd like the set that Woody doesn't need, please :D
I've PM'd my address etc...
Best wishes
chrism
Postby HJ2 » Thu 14.09.2023, 09:19
Never a dull moment!
Excellent upgrade, as always.
Postby muley » Thu 14.09.2023, 09:55
FunElan wrote:Those of us in the colonies are awaiting the creation of a wiki post with the steps to recreate your "over the counter" rear brake upgrade :-D
...and Berkshire
Postby Tuga2112 » Thu 14.09.2023, 12:38
...and Berkshire
i have the suspision they come from a japanese manufacturer's parts bin :lol:
Re: Front Brakes... A Modern Option (SOLD)
Postby par » Wed 27.09.2023, 12:24
Looks good as usual Jamie!
What make of coilover is fitted to your car, cant quite make out the name on the sticker?
par
Postby Jamie N » Thu 28.09.2023, 09:52
par wrote:What make of coilover is fitted to your car, cant quite make out the name on the sticker?
A man with your previous JDM vehicles should know that logo from a mile away. :-D
Monaco S2 #406
Jamie N
Seal God
Postby par » Thu 28.09.2023, 14:20
Well that's what caught my eye as I thought it looked like Spoon... ...did you get them overnighted from Japan? :D
par
Postby peter canepa » Sat 07.10.2023, 20:44
My God man, I have never seen such a clean underside of our cars. Love it!
For my Fed one, Garage queen, do you mind sending the purchase info, If I can buy them here then try to find a mechanic. currently still searching
Damm this car looks good
peter canepa
Return to Elan Products for Sale (Used Products for Sale)
