Jackonicko wrote:They were on the aftersales list.
Enright wrote:... my point is that throwing a new aircon pump at this is like changing your master cylinder when your brake lights keep blowing, or the ECU when you have a misfire. In other words it doesn't make sense, so I urge you to try to find the electrical problem rather than spending a lot of money on a component which probably wouldn't cure it.
... and some nice analogies to boot!Enright wrote:...I'm going to move this from "Part Cross-Reference" to "Problems - Need Help!".
Sy V wrote:I see your point Neil, but it might help londoner (whose a first-poster) if you'd left a shadow of the original so that he can find his thread again.
I'll sort something... done.![]()
Enright wrote:But the compressor's mechanical.![]()
I think your problem is more likely to be a fan that is either burning out or has been fouled by the surround corroding.
Bearing that in mind, I'm going to move this from "Part Cross-Reference" to "Problems - Need Help!".
GeoffSmith wrote:Presumably it's the 7.5A fuse at position A2 - heating and aircon diagram. This only feeds the clutch winding (which I assume is within the compressor), so it would be worth checking the trinary switches and wiring for intermittent shorts first.
If you do need to replace the compressor, the part number is A100E6113F and they were on the January 2007 list for £199 incl. VAT but are now £213 + VAT.
Dave Eds wrote:Jackonicko wrote:They were on the aftersales list.
which is never far away
