Blaster wrote:So today in this heat of 37C my temperature gauge got to normal while driving at 40ish.
chrism wrote:...and in case anyone's wondering 15psi = 103kPa, and our our 120kPa caps = 17.4psi.
(Presumably this is the origin of the '120' etched into the coolant header cap?)
So lotusflasherman, I reckon you can stretch your thermodynamic efficiency a stage further; many Vauxhall apps seem to be 140 kPa...
lotusflasherman wrote:The Service Notes also say Fans On at 110°C and Off at 103°C (KD.4 Page 7)
Grosbard wrote:I have the normal thermostat installed, but a different radiator fan thermal turn-on switch installed. My fan turn-on switch is a 185/195 Fahrenheit unit which means 85/90 in Celsius. So when I'm driving and it's hot outside (I live in California), the water temp is pegged at the 1/4 mark or maybe a tiny bit higher (which Lotusflasherman's post above describes as 75 Celsius). So, I'm wondering, is this too cold for optimal engine health? My intuition is that the thermostat wouldn't even open if the engine wasn't warm enough, so my situation is totally fine, but wanted to get other opinions on this. Thanks!
Grosbard wrote:Generally, I'd say the temp is locked at exactly the 1/4 mark when the car is moving.
The only time it goes higher is when I'm idling or if I'm moving on a pretty warm day (above 80 Fahrenheit (about 27 C)). In those situations the temp is locked at a tiny bit past 1/4 (I'd estimate about 5/16ths). I believe that's the point that the fans kick in.
The data above tells me that I'm probably not "over cooling" because on cooler days when I'm driving (and therefore the fans are NOT on), the temp is pegged at 1/4, which must mean that 1/4 is safe. But wanted to see if I'm thinking about this properly.
