v-f-m thermostat kit
Postby chrism » Fri 07.04.2023, 08:35
A recent RockAuto foray resulted in an 88C Gates thermostat with no gasket :( - my fault entirely.
82C thermostats are 'OEM' for our m100s and most seem to be sold w/out gaskets for some reason, which adds to the 'faff' factor.
I asked a local car accessory dealer (who amazingly has stuff on shelves - tho' not this item...) and he used the Wiki QTH100K part number to get this over the counter the next day:-
A £10-95inc vat + del Land Rover thermostat kit inc gaskets? :) - 'that'll do nicely, Sir...'
Hope this helps.
chrism
Re: v-f-m thermostat kit
Postby muley » Mon 15.05.2023, 07:21
Thank you for that.
They seem readily available. A new one fitted perfectly and my temp gauge is steady at 1/4 and heater is toasty.
1995 Palacio S2 no 507 : 1991 Aqua Blue SE Honda Jazz 1.3 2006 Ford Focus 2.0 Duratech
Postby Tuga2112 » Mon 15.05.2023, 11:00
ive fitted a thermostat from a mini on mine recently and it seems to be below the 1/4 line always. ill probably replace with this sometime
as a side note. what does v-f-m stand for ?
1991 elan se
1991 elan se project
91 MR2 Turbo (import) project
94 Celica GT4 (Import)
94 4Runner
98 Celica SR
Postby Dave Eds » Mon 15.05.2023, 11:11
Value for money.....
Postby lotusflasherman » Tue 16.05.2023, 01:08
I don't want 'to rain on your parade' but I can't see the "jiggle valve" in the plate that should be there for vertically mounted thermostats like in the M100's .. AND be fitted with it uppermost! It stops air being trapped in the thermostat housing.
Like this one ..
If I remember correctly I'm using a thermostat specified for a diesel Astra Van .. it's got the valve but opens at a slightly higher temperature .. for better thermal efficiency and hence more power.
Postby muley » Tue 16.05.2023, 07:47
:oops:
I'll add a hole and jiggle pin (small stainless split pin)
Return to Heating and Cooling
