Coolant leak from Turbo?!! - and other Questions..
Postby Gordon » Sun 13.09.2009, 18:03
Here's one, which someone may have come across before, and therefor have a quick answer to!!
I'm loosing a small amount of coolant - no visable leak when hot, however - When the engine is cold, if I remove the header cap, coolant dribbles down the front of the precat, and drips off the front precat-flange to downpipe stud.
I've peered in as best I can, but the heat shields obscure the view - it's not either the turbo feed or return rubber hoses, checked them.
Any ideas?
Gordon.
1990 M100, Calypso Red
2005 Vectra C....
Gordon
Re: Coolant leak from Turbo?!!
Postby Gordon » Mon 14.09.2009, 08:47
Nobody seen this before? - I'll take the heat shields off ASAP, try and get a better view...
Gordon
2005 Vectra C....
Gordon
Postby Monty » Mon 14.09.2009, 11:42
Gordon,
not seen that before, could be several things but you need to remove the shields for further inspection
1st to check is the Water feed pipes going to the Turbo
2nd might be worth having a block test done to rule out HG failure, if the gasket has gone piston to waterways then you will get water in the exhaust system.
God knows from there
Turbo internal damage, ie cracked casing were the waterways are :?
Keep us all up todate on your findings
Postby Gordon » Thu 17.09.2009, 09:31
Well, having dug further into this problem, it is indeed a failed turbo.
The turbo main body has developed a crack, right behind the exhaust turbine, through to the water gallery!
result - when standing cold, exhaust manifold fills up with coolant! - Lots of steam on startup! - good job I've not got a cat!
Gordon.
2005 Vectra C....
Gordon
Postby mikeydude » Thu 17.09.2009, 11:34
Ouch..sounds expensive.
There are companies that can weld cast iron and alloys for that matter.
My dad had a cast arm on a textile machine repaired a while back and it was a very intricate job!
mikeydude
Postby Monty » Thu 17.09.2009, 12:32
Gordon wrote:Well, having dug further into this problem, it is indeed a failed turbo.
Gordon.
Thats bad news :( and never heard of anyone on the forum having that problem so it`s got to be rare.
Re: Coolant leak from Turbo?!! - and other Questions..
Postby Gordon » Wed 23.09.2009, 19:16
Having obtained a very nice 2nd hand unit, I'm in the process of tidying up my mainfold & plenum/precat etc..
sorting out various sheared bolts and tatty bits of heatshield - many of you know the same story...
I question comes to mind - should I port the wastegate while It's all in bits like this?
I have a perfectly servicable standard exhaust, and no plans to modify in any way... however the question remains...
Is there any disadvantage in porting it?
TIA,
Gordon
2005 Vectra C....
Gordon
Postby tigerdog » Wed 23.09.2009, 20:52
Gordon wrote:I question comes to mind - should I port the wastegate while It's all in bits like this?
Yes, I would definitely port the wastegate. There seems to be no downside and though you may plan to keep the exhaust standard now, you might change your mind in the future. Whether replaced due to tinworm or advancing middle age and concomitant desire for more power as compensation for declining... *cough*, erm, not that I have personal experience...
Or maybe you sell the car someday and the next owner wants a mountain chip - what a nice thing to be able to mention in your for sale advert.
Postby Gordon » Sun 27.09.2009, 20:52
For anyone who's interested, This is where my turbo housing had cracked - resulting in a coolant leak into the exhaust turbine housing.
After standing overnight, the whole exhaust would be full of coolant - Lots of steam on startup!!
2005 Vectra C....
Gordon
Postby GeoffSmith » Sun 27.09.2009, 21:04
Looks like you might need some stainless wastegate manifold studs....
Return to Heating and Cooling
