by Upset99 » Fri 25.06.2010, 14:00
I dont get the car much on the highway but when I do, I experience a problem. At about 70 MPH, the A/C stops blowing or down to a trickle. If I let off the gas a little, the A/C starts to blow but will stop again. It seems that if I want the car's A/C to run well, I must drive about 65 MPH.
Ideas?
Upset99
- Tinkerer
by superbad » Fri 25.06.2010, 20:33
I get that too, but only on a long hill when the car is under boost for an extended period of time (swamping the manifold vacuum). The heater control valve is vacuum operated, and I think if you lose vacuum, it opens up and lets coolant go to the heater. You might have a slight vacuum leak somewhere.
superbad
by Upset99 » Tue 29.06.2010, 15:11
thank you...that sounds right
Upset99
- Tinkerer
by Andy_J » Tue 29.06.2010, 21:54
Not sure if it is the same with the Elan, but the Cartlon shuts the aircon off over 150mph to aid acceleration
90H BRG SE 48,000 Miles
Andy_J
Return to Heating and Cooling
