by andrewp » Tue 21.05.2024, 21:59
The AC compressor has a stubby check strap which links the top of the compressor with a threaded hole on the upper portion of the mounting bracket.
I (believe) I have lost mine. Can someone measure the dimension of this strap . . . . center hole to center hole. I'll fabricate something out of stainless steel.
Andrew in Edmonton, Alberta, Canada
andrewp
- Tinkerer
by Tuga2112 » Tue 21.05.2024, 22:20
i can help you, however, that wont happen until wednesday. im currently on a rather busy period and wont have time to check my AC car for anything under the bonnet
by andrewp » Thu 23.05.2024, 20:51
I measure it as two 10 mm bolt holes (drilled to 11 mm for clearance) that are spaced 47 mm from bolt center to center.
I found a suitable Isuzu part.
AP
andrewp
- Tinkerer
Return to Heating and Cooling
