feet only heater
feet only heater
Postby johnj » Tue 01.07.2025, 21:20
Hi All
Coming home tonight in the pouring rain (what heatwave) the windscreen fogged up. Set the heater to clear the screen , no difference. On inspection the air flow only goes towards the footwell regardless of which position is selected. Any ideas how to rectify this problem
johnj
Re: feet only heater
Postby FunElan » Tue 01.07.2025, 21:25
The direction of the air is vacuum operated, so either remove radio or glovebox and have a peek at those hoses back there, possible with a snake camera. Maybe a hose popped off?
FunElan
Postby johnj » Tue 01.07.2025, 22:09
Thanks I'll have a look at the weekend. Was worried the dashboard might require removal.
johnj
Postby johnj » Wed 02.07.2025, 18:27
I had a look today 2 pipes off. Luckily both in the foot well a corrugated one and a normal vacuum hose. Lucky it was there as I could not see the other end of the vacuum pipe. Remember you need the engine on to change which vent the air comes from :oops: Thanks
johnj
Return to Heating and Cooling
