Ashaman wrote:When you say "turns round" do you mean it just moves freely? If so, the metal linkage has probably come out of place or the knob is broken.
Behind the fascia a metal rod is supposed to snap into the back of the heat selector knob. It sounds like it is no longer connected.
mickmick wrote:ok, latest update on the heater problem, and to get my thread back to the tp and noticed again:
The rotary knob turns
It is DEF connected to the control rod, as when i turn the knob the rod moves in a backwards and forwards manner, my next port of call is somewhere in the enigne itself, or so i beleive, any tips on what to look for/access to the area i need to be working in, i am assuming is going to be at the back of the engine, in those ever so dificult to reach areas
Mick
Doc_Fizzix wrote:Does the heater work? I mean does it get hot?
It could be that there is a vacuum leak in the lines going to the heater control knob. The heater vent flap are controlled by amount of vacuum pressure at the knobs.
Downlad the manual so you can read up on it and chase that gremlin away.
Ammateur gynacology? sound fun
