Cooling water pump
Cooling water pump
Postby david33 » Fri 19.08.2005, 13:36
Hi to all!
I have a problem with water pump.The water goes slowly out.It is possible to repair or i must to buy new one.If i must to buy,when i can do this?
Thank you very much!!! David
david33
Postby Sy V » Fri 19.08.2005, 14:04
Look here:
http://www.lotuselancentral.com/forum/v ... php?t=5022
If you mean the elctric recirculation pump.
Here's SJ Sportscars' price!
Cooling system | Water pump and repair kit
COOLANT RECIRCULATION PUMP A100K6018F EACH £168.36
If you mean the mechanical pump:
WATER PUMP A100E6172S EACH 97.85
Return to Heating and Cooling
