Is the new owner of J505 LKB on here?
Read here for help with getting started on postings.
Postby Mutley00 » Sun 21.02.2021, 15:15
Hi,
I was the previous owner and have just discovered a large tin of paint for the car and an aerosol that I had made up from the stuff in the tin.
Getting touch up paint that matches perfectly is a real pita, so you are welcome to it all.
I can also help with a bit of history
Cheers, Andrew
It's better to have fought and lost, than not have fought at all.
Mutley00
Re: Is the new owner of J505 LKB on here?
Postby Mutley00 » Sun 24.10.2021, 14:46
Bump! If I dont hear anything soon, the paint is going in the bin which seems such a waste.
Mutley00
Postby Fredjohn » Sun 24.10.2021, 14:58
You might get a taker other than current owner if you stated the actual colour, along with paint code if original Lotus colour.
You might also want to delete the double posting.
Good luck.
Postby Simon_P » Sun 24.10.2021, 16:16
Fredjohn wrote:You might also want to delete the double posting.
I'd echo Fredjohn's comments.
Return to New User Help with Postings and Extras
