Post your cries for help about using this forum. Please do not use this section for Elan-related problems.
by ailwyn » Sun 24.08.2008, 21:27
If you notice any problems or have any questions regarding the upgrade/new style please post here.
- Forum Member
by Monty » Sun 24.08.2008, 21:54
The main forum page is fine but when i`ve clicked on a subject heading and the same as replying the window is offset to the right and a large gap to the left
but the heading at the top is ok ie full length of the screen
- Chunder King!
by Specky » Sun 24.08.2008, 22:08
Did you know you can't search for N/A...
It turns out it's common...
Also.. not all my posts are appearing, this is the second time I've wrote this...
by ailwyn » Sun 24.08.2008, 22:17
Jay,
What browser are you using, it all seems fine to me with no offsets, I'm using firefox 3.
Dave,
Are you seeing the post successful message after submitting? I'll look into the search, but the / may be throwing it off. Also the search index is in the process of being re-built so some posts may not be included until the search index is complete.
Ailwyn
- Forum Member
by markv » Sun 24.08.2008, 22:42
I get exactly the same offset problem. I'm using Internet Explorer 7
by ailwyn » Sun 24.08.2008, 22:49
Yup, confirmed, I just tried IE and get the same problem.
Al and I will take a look and fix as soon as we can.
Ailwyn
- Forum Member
by markv » Sun 24.08.2008, 22:52
In the "Members" list option, you don't seem to be able to sort any more, only list in order of date joined. Previously you could list by total posts and other criteria, ascending or descending
by markv » Sun 24.08.2008, 23:00
The only links which work along the bottom of the main LEC banner heading are the external ones, WikiLEC, Mountain Chips and Donate. The rest come up "Page Not Found".
Also, I thought my time was previously set correctly (and automatically), but I've just had to go into my preferences and click 'Yes' against the "Summertime" option to get the correct time displayed.
by Monty » Sun 24.08.2008, 23:14
ailwyn wrote:Yup, confirmed, I just tried IE and get the same problem.
Ailwyn
Yep IE 7
- Chunder King!
by ailwyn » Sun 24.08.2008, 23:27
Al and I have been looking in to this, IE 7 is affected, IE 6 is fine.
I don't have an immediate answer as to why or how to fix it, so please bear with us while we resolve the problem.
Mark,
The links at the top should now be fixed.
The migration doesn't seem to have brought that flag with it for DST, apologies.
In the member's list, click on the column headings to sort, a second click changes between ascending and descending, for example, click on Posts, then it will sort the list in ascending order, click posts again to sort in descending order.
Ailwyn
- Forum Member
by GeoffSmith » Sun 24.08.2008, 23:39
"NO_AUTH_READ_HOLD_MESSAGE" when trying to read unread PM!
- Kitty Fiddler
by ailwyn » Sun 24.08.2008, 23:48
Geoff,
You're still a mod and everything is as it was previously... can you try logging out and back in?
Try a forced refresh/reload (hold down shift while reloading to force the browser to not use the cache).
Failing that scroll to the bottom of most pages and use the pull-down to jump to the relevant forum.
As for the PM, don't know, it's working fine for me, maybe re-logging in will clear it?
Ailwyn
- Forum Member
by ailwyn » Sun 24.08.2008, 23:49
It could be your mailbox is over limit, do you have 50+?
Ailwyn
- Forum Member
by al » Sun 24.08.2008, 23:51
Monty wrote:Yep IE 7
I think I've sorted the IE7 problem, shout if you find other layout issues.
al
- LEC Bit Basher
by ailwyn » Sun 24.08.2008, 23:54
Al, IE7 problem is fixed.
For anyone still getting problems please refresh, while holding shift on the keyboard, this forces the browser to go back to the server and not use it's cache.
- Forum Member
by Monty » Sun 24.08.2008, 23:54
ailwyn wrote:Al and I have been looking in to this, IE 7 is affected, IE 6 is fine.
Ailwyn
Seems all sorted now
- Chunder King!
by markv » Mon 25.08.2008, 00:02
ailwyn wrote:Mark,
Ailwyn
- No Next/Previous options on multi-page threads
- No Rank number on the Members list pages, so I can no longer see that I'm the 78th highest total poster (yes, I know it's very sad of me!)
by GeoffSmith » Mon 25.08.2008, 00:20
ailwyn wrote:Geoff,
You're still a fiddler and everything is as it was previously... can you try logging out and back in?
Ailwyn
Already done the obvious!
Oh, and where is the "view my posts" button?
- Kitty Fiddler
by ailwyn » Mon 25.08.2008, 00:22
Mark,
It's there for me, in IE and Firefox.
- Forum Member
by GeoffSmith » Mon 25.08.2008, 00:24
ailwyn wrote:It could be your mailbox is over limit, do you have 50+?
Yes. Deleted a few and it reads OK.
GeoffSmith wrote:"NO_AUTH_READ_HOLD_MESSAGE" when trying to read unread PM!
Message as useful as SAP anti-help.
- Kitty Fiddler
Return to Forum (not Elan!) Questions/Problems
