Post your cries for help about using this forum. Please do not use this section for Elan-related problems.
by Saltire » Tue 29.12.2020, 20:19
<fact supply> Just the dip beams as far as I can see from the reflection in the garage door </fact supply>
I also note that if I disconnect and
immediately reconnect (<3 seconds), the phenomenon doesn’t occur.
- Location: Left foot in Wiltshire, right foot in Gloucestershire, heart in Scotland
by sheriff464 » Wed 30.12.2020, 08:30
Hello all, I have a battery isolator somewhere in the cabin!! ; when I replace the red key, the headlamp pods cycle up and down with just the dip beam showing! Cheers from Clive.
sheriff464
by GeoffSmith » Wed 30.12.2020, 20:07
Is it an S2 Clive?
- Kitty Fiddler
by sheriff464 » Wed 30.12.2020, 20:46
Geoff, yes S2 Number 742.
sheriff464
by exeterjeep » Sat 29.07.2023, 11:36
I know this thread is a bit old, but,
Changed my battery (S2) yesterday, having read this thread some weeks ago was waiting from some noises at the front, when I reconnected the neg terminal -- and nothing happened. Mine is number 121, may be it happens on later ones, can't imagine why there would be a difference.
Having just tried the lights, only the lh one worked for the first 5 attempts (light switch or flash), but next time, and subsequent, both were working.
exeterjeep
by sheriff464 » Sun 30.07.2023, 14:22
exeterjeep wrote:I know this thread is a bit old, but,
Could just be a dry joint on the headlamp electrics! Try disconnecting the two connectors and spay some contact cleaner or switch cleaner (Maplins) into the joiners,worked for me when I had a blinking pod! Clive.
sheriff464
Return to Forum (not Elan!) Questions/Problems
