Upgrade Related Issues
Post your cries for help about using this forum. Please do not use this section for Elan-related problems.
Re: Upgrade Related Issues
Postby Rambo » Mon 25.08.2008, 21:42
Last night I'm sure the forum was showing current time ie British Summer Time (BST) Now It appears to be showing Pacific time. Is there a facility for showing BST ? Or GMT when the clocks change next month :cry:
Postby ailwyn » Mon 25.08.2008, 22:18
Mark,
It's showing local time for me.
Have you checked your profile to see what timezone you are set to?
Ailwyn
Postby GeoffSmith » Mon 25.08.2008, 22:53
Mine transferred across to UTC+1 OK but I see there is an automatic BST option now which seems to work.
Postby GeoffSmith » Mon 25.08.2008, 23:08
Is that an online banner hidden behind the quote button?
Postby XiPHiAS » Tue 26.08.2008, 08:11
I miss the "show own threads"-button/link. I used at first when i visite the forum, after that I used the "show new posts"-button/link.
1994 Lotus Elan S2 #131 // Lotus Elan M100 S2 Registry
http://www.lotusforum.be :: Benelux Lotus Community
Ypres Lotus Day - International Lotus gathering & tour
XiPHiAS
Postby al » Tue 26.08.2008, 08:50
GeoffSmith wrote:Is that an online banner hidden behind the quote button?
It is indeed :)
al
LEC Bit Basher
Postby al » Tue 26.08.2008, 08:53
XiPHiAS wrote:I miss the "show own threads"-button/link. I used at first when i visite the forum, after that I used the "show new posts"-button/link.
You can view your own posts by clicking on "Profile" at the top, then on "Show your posts".
al
LEC Bit Basher
Postby Rambo » Tue 26.08.2008, 12:42
ailwyn wrote:Mark,
Ailwyn
Interesting - it started OK then changed somewhere along the way to Chinese standard time :shock: But not by me ! Probably been watching too much Team GB and eating too many BBQ spare ribs :lol:
Postby RayD » Tue 26.08.2008, 13:45
For someone on dial up connected at 48Kbps it seems to have slowed down a bit. Will it be because the new version is more complex or will it be my imagination? :?
Postby ailwyn » Tue 26.08.2008, 14:02
Ray,
There is more complexity to the site layout and this may well slow down your dial-up connection... we do have some de-bugging switched on at present that does also have a small overhead.
Ailwyn
Postby al » Tue 26.08.2008, 14:07
I wouldn't have expected it to change a great deal to be honest, the number of graphics on the page hasn't really changed much from the old forum, maybe there's a bit more HTML being chucked around but not a huge amount more.
We've got some debugging on at the moment which might be slowing things down a bit.
al
LEC Bit Basher
Postby RayD » Tue 26.08.2008, 15:46
Thanks for that... you probably won’t tell on broadband but it's noticeable on dial up.
It takes Edit...1m:10secs to refresh this page.
1m:49 for a random page to appear from the unread posts (Peco page 26)
Only 4 seconds to move from this page to the index.
Postby al » Tue 26.08.2008, 16:36
Did a quick check on sizes...
This page:
Documents (1 file) 6 KB (55 KB uncompressed)
Images (44 files) 90 KB
Objects (0 files)
Scripts (3 files) 16 KB (29 KB uncompressed)
Style Sheets (5 files) 16 KB (72 KB uncompressed)
Total 128 KB (245 KB uncompressed)
So it should take ~30s at 4KB if your browser supports gzip encoding, I'm guessing it doesn't since it's taking you ~70s...
I'd suggest installing firefox3 if you haven't already, the Google webaccelerator may or may not help - it's really designed for DSL speeds rather than dial up but might also be worth a try.
For a direct, side by side, comparison: the total page size for the first page of the thread on which glue to use to fix your hood on the old forum:
Documents (1 file) 11 KB (97 KB uncompressed)
Images (43 files) 121 KB
Objects (0 files)
Scripts (1 file) 9 KB (22 KB uncompressed)
Style Sheets (1 file) 10 KB
Total 151 KB (249 KB uncompressed)
and the new:
Documents (1 file) 12 KB (78 KB uncompressed)
Images (50 files) 126 KB
Objects (0 files)
Total 171 KB (305 KB uncompressed)
The actual HTML size is smaller (78KB vs. 97KB) on the new forum than the old, but the CSS (72KB) is a bigger - although:
- the new CSS compresses to about the same size as the old CSS, and
- the CSS should be cacheable by the browser and only needing to be downloaded once which should bring the repeat size for the new forum down to 159KB compressed, or 227KB uncompressed - which is comparable with the old code even taking the 10KB off for cached CSS on the old forum too.
Granted these are still long wait times if you're using a bit of wet string for your internet connection, but them's the breaks...
Just think, how many times have you loaded a page on LEC so far ? 1000's ?
you've lost a minute of your life waiting for every single one :shock:
No chance of getting DSL put in ? :)
al
LEC Bit Basher
Postby Rambo » Tue 26.08.2008, 17:31
Initially I thought it was slower but today it seems faster and I'm on dial up as well :shock:
Maybe it's time for us to swap our slowband to broadband Ray - I mean think how much better it will be for :porn: :oops: And obviously for loading all these M100 related pictures :m100:
Postby RayD » Tue 26.08.2008, 19:17
Thank you Al.
I'm sure you're right Mark. ;-)
Postby XiPHiAS » Tue 26.08.2008, 21:15
Yes i found that but the old link was so ... so easy and fast ...
XiPHiAS
Postby Enright » Tue 26.08.2008, 22:47
Is it possible to get a preview of the message when you get emailed news of a new PM?
Postby ailwyn » Wed 27.08.2008, 08:27
Enright wrote:Is it possible to get a preview of the message when you get emailed news of a new PM?
Anything's possible :-D
Postby Enright » Wed 27.08.2008, 08:28
OK, I'll phrase the question a different way:
I miss that facility. Can we have it back please?
Postby Monty » Fri 29.08.2008, 22:47
Smilie problem alert
When i click on the `view more smilies` an d a click on a smilie it`s not appearing in my reply, infact the smilie code appears on the same page as the smilies in the top left corner. :? so have to copy and paste the code to get it to work
I`m on IE7 with Vista
BTW can we have the `Mark forums read` back at the bottom of the page plz
Return to Forum (not Elan!) Questions/Problems
