How to specify a NON-PROPORTIONAL FONT
Post your cries for help about using this forum. Please do not use this section for Elan-related problems.
Postby nitroman » Sun 20.01.2008, 05:54
How can I specify that I wish a post, or a portion of it, to use font COURIER NEW, size 10? That would allow me to vertically align information, making the information neat, and therefore easy for all to understand & use.
nitroman
Postby inkitin » Mon 21.01.2008, 23:59
Nitroman
Not sure if this will work but let's give it a try !!
[font=courier new]How does this look to you?[/font]
Hmmmm that didn't work !!
Try again
    How about this?
    Then this?
    and so on?
Is that OK?
It'll only let me do Verdana :(
I suppose you could always make it bold or italic :?
91 SE Calypso Red
inkitin
Postby GeoffSmith » Tue 22.01.2008, 00:44
Code: Select all
WWWiiiWWW
iiiWWWiii
:wink:
Postby inkitin » Tue 22.01.2008, 00:49
Inkitin suitably put in his place !! :oops: :-D
91 SE Calypso Red
inkitin
Postby GeoffSmith » Tue 22.01.2008, 00:53
Or Iii has also learned a new skill (as have I)!
  • A
  • B
  • C
  1. A
  2. B
  3. C
  1. A
  2. B
  3. C
I can do lists as well now! :D
Postby dapinky » Tue 22.01.2008, 17:29
Is it just me that's lost??????
Am I the only one who hasn't got a clue???????
:wtf:
Postby nitroman » Tue 22.01.2008, 23:38
dapinky wrote:Is it just me that's lost??????
:wtf:
Any two lines of text with the same number of characters in each line in a monospace typeface should display as equal in width, while the same two lines in a proportional typeface may have radically different widths. This occurs because wide glyphs (like those for the letters W, Q, Z, M, D, O, H, and U) use more space, and narrow glyphs (like those for the characters i, t, l, and 1) use less space than the average-width glyph when using a proportional font.
It would really help in displaying columnar information to have the use of fixed-width fonts.
nitroman
Postby GeoffSmith » Tue 22.01.2008, 23:44
Code: Select all
Postby Doug » Wed 23.01.2008, 01:04
so what you're subtly saying Geoff is that he should type
[ code] text text text [/code]
Postby nitroman » Wed 23.01.2008, 01:24
Kinda awkward, but better than nuthin'
Code: Select all
Qty  Part #     Desc.
2    120-6816   Caliper
1    15Q-6824K  Pads
2    160-5844   Rotors
2    230-0150   Bolt kit (8pk)
nitroman
Return to Forum (not Elan!) Questions/Problems
