Sig block parsed incorrectly
Post your cries for help about using this forum. Please do not use this section for Elan-related problems.
Postby rival » Wed 10.09.2008, 17:57
Hi,
I've just realised my sig block links don't work as they should. And I can't even show you the text I've submitted because of the same issue. This is what the forum saves:
Code: Select all
[url=http://www.rivals.talktalk.net/lotus]1990 Lotus Elan SE Turbo[/url]
[url=http://www.rivals.talktalk.net/mx5]1999 Mazda MX-5 10th Anniversary Edition[/url]
But what I submitted had lotus with a lower case "l".
And the word "lotus" above was typed in lower case when I posted, but it gets automatically converted to Lotus with a capital L.
I presume this is some forum rule that has been set up? Before I change my website structure to "elan" instead, thought I'd check whether there was any way around this problem.
Thanks,
James
P.S. Just done another preview on this post, and noticed that the forum has now capitalised Elan for me. Does it do it for every make? It'll make any link using those words in lower case FAIL. Help!
P.P.S. I don't think the old style forum used to do this.
rival
Re: Sig block parsed incorrectly
Postby paulrwebster » Wed 10.09.2008, 19:19
Well it is obviously a feature, can you not work around it by pointing the Lotus link to your main site at http://www.rivals.talktalk.net and let people drill down from there?
paulrwebster
Postby al » Wed 10.09.2008, 19:39
sorted it.
al
LEC Bit Basher
Postby rival » Wed 10.09.2008, 23:21
Al,
Thanks for sorting that so quickly. I see it works retrospectively, so my original post will be baffling to anyone now reading it :D
James
rival
Postby al » Thu 11.09.2008, 09:08
rival wrote:Al,
James
No problems, thanks for spotting it and calling it out !
al
LEC Bit Basher
Return to Forum (not Elan!) Questions/Problems
