WikLECi Not Availible
Post your cries for help about using this forum. Please do not use this section for Elan-related problems.
Postby Freelander » Tue 13.01.2009, 09:18
Is it me or is the WikiLEC not available?
Using the hotkey above the Index Board
I'm getting the HTP5500 Server Internal Error message:
Most likely causes:
The website is under maintenance.
The website has a programming error.
Any help would be appreciated
1990 SE Turbo - Silver - Work in Progress (Slowly)
'Go slow now - go fast later'
Freelander
Re: WikLECi Not Availible
Postby ailwyn » Tue 13.01.2009, 09:59
John,
Works for me.
Ailwyn
Postby al » Tue 13.01.2009, 10:21
Seems ok to me currently…
Ah, it's been down for a little while in fact, the culprit's been found and duly wrist slapped (another admin on that machine had upgraded some software, but inadvertently broke the wiki), but I will be adding some extra monitoring so that with any luck I'll know about these outages before you do.
Deepest apologies for the inconvenience.
a.
al
LEC Bit Basher
Postby GeoffSmith » Tue 13.01.2009, 13:44
Thanks Al. It's good to know that perople are using it. :D
Return to Forum (not Elan!) Questions/Problems
