Circuit diagram in WikLECi not there
Post your cries for help about using this forum. Please do not use this section for Elan-related problems.
Postby alexg » Wed 08.04.2009, 11:43
Hi
I'm trying to look at the circuit diagram in the wiki for the inition and alternator circuits but the picture just comes back with a red X in the corner.
Here is the link http://wikilec.9600.org/images/7/79/MJ25-02_Starter%2C_Alternator_%26_Ignition.gif
Any help would be greatly appreciated as I have an itermittent problem with my battery warning light which comes on sometimes even though the voltmeter is reading a constant 14v so the alternator is ok.
Alex
alexg
Re: Circuit diagram in WikLECi not there
Postby GeoffSmith » Wed 08.04.2009, 19:10
It's there for me. I've e-mailed you a copy.
Postby alexg » Thu 09.04.2009, 20:43
Thanks Geoff got the email
Not sure why that one would not work either as all the others worked.
alexg
Postby paza1 » Fri 10.04.2009, 20:35
Just FYI, it doesn't work for me either...other gifs work...strange
Mark
Silver 1992 SE Turbo.
paza1
Postby GeoffSmith » Fri 10.04.2009, 21:51
It doesn't work for me with Internet Explorer but does with Firefox. :roll:
Postby paza1 » Fri 10.04.2009, 22:05
Thanks for the info. Geoff. Must remember to actually use Firefox and not just download it, try it and then revert to IE7 :bonk:
Mark
paza1
Postby HJ2 » Wed 07.04.2010, 18:53
Alex, did you find the cause and a cure for the red light?
Return to Forum (not Elan!) Questions/Problems
