Outside Temperature
Post your cries for help about using this forum. Please do not use this section for Elan-related problems.
Outside Temperature
Postby Denny » Wed 24.02.2010, 08:35
Renault Clio 51 reg, outside temperature gauge is reading 10 DegC to high.
Annoying more than anything.
Could this just be the sensor? If so where is it and where can I get one from?
Denny
Re: Outside Temperature
Postby VagueShot » Wed 24.02.2010, 08:38
Is it always 10 degress too high? For instance, if the temperature is 15 outside, will it show 15, so it might be the first digit of the display going wrong.
The outside temperature gauge on my Elan always shows the same. Is that correct?
James Miller
http://anonw.wordpress.com/tag/lotus-elan/ - Ramblings of an anonymous widower and sometimes his ever-faithful Lotus Elan.
VagueShot
Postby Specky » Wed 24.02.2010, 09:29
I think the OAT sensor is under the wing, but don't quote me.....
Postby Denny » Wed 24.02.2010, 13:57
VagueShot wrote:Is it always 10 degress too high? For instance, if the temperature is 15 outside, will it show 15, so it might be the first digit of the display going wrong.
If the outside temp is 5 the digital display reads 15 hence if the outside temp is -4 it will read 6.
Denny
Return to Forum (not Elan!) Questions/Problems
