MOT Passed!!
MOT Passed!!
Postby Fredjohn » Fri 01.08.2014, 11:34
MOT passed with a small advisory on FOS shock "misting oil". 12 months of happy Elan motoring now ahead :burnout: :burnout: :D :D
Really pleased as I spent 2hrs removing and fixing the reverse light switch (broken wire on switch itself), only to find it's not part of the MOT!! :shock: :shock:
The brake meter the garage had was faulty and was not reading on the one side, but readings on the other side were F345 R85 H'brake 150. He still passed it as he could see all the brakes were new and was happy. !!!!! No I'm not saying who or where! I know the rear is a bit low and not strictly in balance with the front brakes, but a bit of bleeding should resolve that. The car does stop rapidly (is that an oxymoron?) from 60mph under emergency braking in a dead straight line, so I have full confidence in my brakes. Would the machine have worked if I had reversed on to measure the other side?
The hazard lights only work if I indicate left or right (ign. on or off). I am sure this is not a design feature and would welcome thoughts on why this is the case: did read something about this somewhere, but can't find it.
Exhaust CO emissions were exactly 3% and HC 184, so well within tolerance.
Off to Preston next weekend to do a Coast to Coast (UK style) from Morecombe to Scarborough with CLNW: dinner at the end at Ayton Lodge Hotel. Let's hope weather is good.
Re: MOT Passed!!
Postby Rob P » Fri 01.08.2014, 14:20
Great News on another year driving the Elan, well done mate and enjoy the coast to coast run :burnout:
simplify and add lightness
1997 Lotus Elise S1 - Metallic Racing Green
Rob P
Re: MOT Passed!!
Postby maz_r » Fri 01.08.2014, 20:49
NIce one John.
We can have a look at your hazards on the 21st - suspect it might be a wonky flasher, but I'll do some pre-work if you can wait that long?
Zoom..zoom.. :burnout:
maz_r
Binary Bodger
Re: MOT Passed!!
Postby Fredjohn » Fri 01.08.2014, 21:09
Thanks Martin, appreciate your help.
No rush at all: hazard is sort of working! Yes can wait till then.
See you 21st.
Re: MOT Passed!!
Postby Andy_J » Fri 01.08.2014, 22:10
The issue with the hazards could be a problem with the switch, they are known for being a bit flakey
90H BRG SE 48,000 Miles
Andy_J
Return to General
