M100 on Top Gear
M100 on Top Gear
Postby pineapplecharm » Thu 19.05.2016, 16:00
I knew about the original review from 1990 but only recently became aware that the M100 turns up in a 'British sports car' feature at the end of Series 15.
A few laughs in there, not least the unfortunately familiar window tribulations. Funny that when it's a car you own you immediately start thinking about how you'd fix it. Come on, man! It's probably just the butterfly clip...
pineapplecharm
Re: M100 on Top Gear
Postby Rob P » Thu 19.05.2016, 17:32
To be honest I actually found the whole window issue on the Top Gear program a little hard to swallow as I've never had this happen to mine, I have had the windows out to replace the weather strips and they were a beggar to work on but now they are back in they have worked a treat ever since.
And that will be the kiss of death on it and they'll be failing all over the place now :lol:
simplify and add lightness
1997 Lotus Elise S1 - Metallic Racing Green
Rob P
Postby Giniw » Thu 19.05.2016, 19:56
Giniw
Postby Brit-Car-Nut » Fri 20.05.2016, 03:13
The Top-Gear Season 15 M100 - TVR - Jensen "Tribute" combined two segments are also available from the Manuals list (link below). It is a BIG file but it does eventually load as an MP4 file.
Postby pineapplecharm » Fri 20.05.2016, 09:09
Nice, Giniw! Although I can see why they cut it!
Rob, don't tempt fate. Remember what the acronym LOTUS stands for!
pineapplecharm
Postby Rob P » Fri 20.05.2016, 09:38
pineapplecharm wrote:Rob, don't tempt fate. Remember what the acronym LOTUS stands for!
good point, I am off to pray to the gods for some smooth running over the summer :burnout:
Rob P
Postby Fredjohn » Fri 20.05.2016, 10:37
Giniw wrote:Here is a little bit more: https://www.youtube.com/watch?v=t-fv8llvcvI&t=1160
Interesting to watch...and the other excerpts. But I noticed that the clips are mirror image, presumably to differentiate them from the real broadcasts.
Postby pineapplecharm » Tue 24.05.2016, 08:18
Fredjohn wrote:. But I noticed that the clips are mirror image, presumably to differentiate them from the real broadcasts.
It's to defeat the copyrighted material recognition systems.
pineapplecharm
Postby HJ2 » Tue 24.05.2016, 10:03
pineapplecharm wrote:Nice, Giniw! Although I can see why they cut it!
It turns out I drive an ATAS a then, not a LOTUS! (the A stands for always) :oops:
Postby Kathryn » Wed 07.09.2016, 19:10
Think this ones just been on Dave. Flicked over and just saw the end with a yellow M100 in the studio.
Palacio S2 #540
Kathryn
Return to General
