Whats the push button thing behind the passenger seat ?
Postby simonbuk » Wed 20.07.2016, 17:15
When you take out the piece of interior trim situated behind the passenger seat, there is a rubber push down button which I think is wired up.
What is it/what does it do ??!!
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Re: Whats the push button thing behind the passenger seat ?
Postby lotustonybassplayer » Wed 20.07.2016, 18:33
i believe it could be the inertia switch for the fuel pump if yours is a s2
lotustonybassplayer
Postby John_W » Wed 20.07.2016, 21:09
:smt045 :agree:
Postby simonbuk » Wed 20.07.2016, 23:46
So why would I need/use this ??!!
If I'm upside down in a ditch and I need to turn the fuel pump off ?
Black S2 No.357
Aqua Blue S2 No.385
Simonthesailor
simonbuk
Postby Fredjohn » Thu 21.07.2016, 00:09
simonbuk wrote:So why would I need/use this ??!!
No the opposite!!!! If you are upside down in a ditch, the inertia switch will have gone off automatically, so turning off the fuel pump. Once you get out of the ditch, right the car and wish to re-start it, then you press the inertia switch button to re-connect the power to the pump and reset the inertia switch.
The inertia switch also kills the fuel pump in the event of an impact accident, not just being upside down!
Hopefully you'll never get into that position.
Postby lotusflasherman » Thu 21.07.2016, 00:12
err... No, the opposite. When you're upside down it will have turned the pump off for you. When you've got the car back up the right way you need to reset it to get the pump on again.
Postby lotusflasherman » Thu 21.07.2016, 00:13
Blimey - we must have been typing virtually the same thing at virtually the same time!
Postby Fredjohn » Thu 21.07.2016, 00:14
When 2 posts collide.....word for word almost, but beat you to it!!!
(I couldn't sleep either)
:D :D :D
Edit add:
But not this time :D
Return to General
