yaTech1 (ElanScan alternative)
Postby Giniw » Tue 29.11.2016, 01:26
Hello Everyone,
It's been a while since I started developing my own ElanScan alternative, mainly for fun and also because I wanted to add a few things over the original one. Here are the main features I can think of:
– tested on Windows (7 and 10), should work on MacOS, Linux and Solaris too.
– real time graphs
– filter to find a parameter quickly
– more than two curves at a time
– more visible fault codes
– reset fault codes without deconnecting the battery
– reset block learn memory (BLM)
– reset idle air control (IAC)
– switch on and off the CEL programmatically (:D)
– idle air control manual override (by setting the IAC position or with a RPM target) — has an effect but doesn't work so well for now IIRC, needs more tests
– I don't know if it's just me, but I successfully dumped my ECU ROM with yaTech1 whereas it seems to fail with ElanScan.
(for your information, the tabs advanced explorer, performances tests and especially virtual dyno may be never implemented at all, they are completely empty so far)
PS: you may also notice that the version is already around 7 months old, I haven't had much time nor motivation to work on it lately ;-)
I will try to motivate myself to release a beta in a near future ^^
Giniw
Re: yaTech1
Postby Giniw » Tue 29.11.2016, 01:30
(Oh and by the way, the "About window" plays a couple of the Lotus Turbo Challenge video game musics — a very important feature indeed :lol: )
PS: of course all that wouldn't have been possible without the help from the ElanScan ini file, so ... Thank you for the huge reverse engineering work!!)
Giniw
Re: yaTech1 (ElanScan alternative)
Postby Fetnas » Wed 30.11.2016, 03:33
That's impressive and very interesting.
I have always been interested in having a mini computer monitoring the ECU installed behind the dash for general data logging and such. Having a system that will run on a linux machine would make this a lot easier. Perfect job of a Raspberry Pi.
I look forward to having a look at the Beta when you get time to set if free on the community.
Fetnas
Postby Candles » Wed 30.11.2016, 08:23
Great!
Candles
Postby HJ2 » Wed 30.11.2016, 10:34
:bowdown: I can't wait to beta test :cheers:
Postby Giniw » Wed 30.11.2016, 16:45
Fetnas wrote:Having a system that will run on a linux machine would make this a lot easier. Perfect job of a Raspberry Pi.
I was thinking about developing a tiny specific version for an arduino (logs recording only) but I think the current version might work on a Raspberry PI without modification — I don't know whether it would suit the minimal requirements though.
Giniw
Postby GeoffSmith » Wed 30.11.2016, 17:00
Julien, nice work. Can you save/load ES (.ecu) file format?
Postby Giniw » Wed 30.11.2016, 17:09
It's not done yet, but yes at least the loading will be implemented (and xls/xlsx export too)
I reversed almost 100% of the ElanScan file format but when I paused working on that subject I was still looking for the usage of an integer which seems to be always set to 1 in all my ElanScan files — viewtopic.php?f=34&t=25409.
Giniw
Postby GeoffSmith » Wed 30.11.2016, 18:21
Just posted some additional info.
Postby Elanlover » Wed 30.11.2016, 22:31
Giniw wrote:Thanks :-)
A Raspberry Pi solution would be great. Cheap and no need to lug a laptop around. Could probably be permanently mounted in the car if it had things like a pass through to the stock port, wifi or Bluetooth file transfer, etc.
Postby Giniw » Sun 04.12.2016, 00:20
Et voilà ! :D
I only tested if the opening of an existing log is working, because I don't have my car right here but according to the Serial library error message, I would say the logging feature probably works too.
Now I have to admit it is not the fastest piece of software I have ever seen but it is still usable in my own opinion, even for a large dataset like the one I used (around 30 minutes of logs).
And please keep in mind it's an old Raspberry Pi board that I borrowed, so it must be faster on a more modern one (I tested it on a Model B 512Mo if I am not wrong, please see https://fr.wikipedia.org/wiki/Raspberry ... .C3.A8le_B)
Giniw
Postby JossElan » Sat 02.03.2019, 13:13
Hi all,
Is this software still available and if so, where can i access it please?
JossElan
Postby Hogflash » Tue 05.03.2019, 01:07
FYI, you can also try the DataCat logging software that supports the Elan M100. Windows only, but works on XP through win10. Will import and display ElanScan files.
Available from TunerCat: http://tunercat.com/
Hogflash
Postby Giniw » Tue 05.03.2019, 13:49
Hi,
As for yatech1, still available is a bit too strong a word since I ... never released it (kind of forgot :oops: :roll: ) but I still have it so I am going to try to clean a few things up for a quick release in the next few days (maybe next weekend for instance)
Giniw
Postby HJ2 » Tue 05.03.2019, 15:40
8)
Postby John_W » Tue 05.03.2019, 17:16
:banghead: :bonk: :chair:
:-D :lol: 8)
Postby JossElan » Fri 08.03.2019, 10:30
Giniw wrote:Hi,
Well I’d be more than happy to give it a Linux Mint test for you...
JossElan
Postby Giniw » Fri 15.03.2019, 23:25
(by they way, I haven't forgotten, I am quite busy but I am going to try to put that subject on the top of the to do list ^^)
Giniw
Postby BarryDalHerbert » Mon 22.06.2020, 13:23
Where are you on the path to releasing YATECH1 for real-world testing GINIW?
BdH
Australia
BarryDalHerbert
Return to General
