Cars cheaper to Service and battery change than watches!!!
Postby abmunro » Fri 22.06.2012, 00:03
Yesterday my Tag Carrera made an odd noise as I tried to shake it to wind it up. So I decided it needed a service.
My Wedding is 1st July so I thought I will have to wear my Longines, got it out the case and the Battery was flat.
Went to Beaverbrooks today £275 for service on Tag
Then £70 for new battery for Longines
Neither will be back before wedding
I had a look round Metro Centre for new watch for wedding, may have picked out a Rado
But I'm sure I could get new battery and service on my Lotus for less than £345
abmunro
Re: Cars cheaper to Service and battery change!!!
Postby tigerdog » Fri 22.06.2012, 05:32
Shees! Now I know why I stopped wearing a watch. These days, I just look at my mobile phone. More accurate and I never have to adjust it when I get off a plane. More money for the Lotus! :)
Postby muley » Fri 22.06.2012, 06:55
..but the Lotus has a clock as well. Not that you can see it.
Good luck on the 1st
Re: Cars cheaper to Service and battery change than watches!
Postby RayD » Fri 22.06.2012, 10:17
£70 for new watch battery :shock:
Postby dapinky » Fri 22.06.2012, 10:24
My Rolex keeps perfect time, twice a day it's right! - what do you expect for $4 in H.K. (battery did last 4 years though)
My TAG is fine all the time - but that one was quite expensive at $8 (Dom Rep) - on it's 3rd battery - 69p each 8)
Postby abmunro » Fri 22.06.2012, 10:51
RayD wrote:.
I think the cost is in resealing the case to keep waterproof..
abmunro
Postby dapinky » Fri 22.06.2012, 11:20
Okay, I'll be sensible this time (see what I did there :D ), i had to pay about £40 for a battery in my diving watch - and as said, it is the cost of re-sealing it which gives the biggest outlay. It isnt just a case of screwing the back on and hoping for the best. Anything decent will then have to be tested at it's rated presure, and that can be a fraught experience in itself.
Whilst many/most owners would consider 'waterproof' to be getting a bit damp in the British summer, or a splash in the swimming pool on holiday, some of us use these things as tools not just ornamants.
If a watch is rated to 200m it only proves that it will stay waterproof whilst 'static' at that depth/pressure - if you actually move it around (like wearing it!) it will only be rated at 50-100m - so you can virtually ignore what it says on the watch face!
My Citizen is actually rated to 300m USE (but would have 1000m as it's static rating) - as such it is pressure tested in a barimetric environment at 1000m when refitting the battery.
The whole cost involves not only the materials, labour and testing but also includes an element of 'insurance'. No-one is going to fit a battery for a fiver if they stand to lose hundreds or thousands of pounds in repairs if it should leak in normal use.
Postby addict » Fri 22.06.2012, 23:19
i like cristopher ward watches u should check them out
addict
Postby Monty » Sat 23.06.2012, 17:10
If i was you i`d just SORN the watch :lol:
Postby abmunro » Sat 23.06.2012, 17:36
addict wrote:i like cristopher ward watches u should check them out
I liked the look of one but its only available to pre order, so i would have it for wedding
I only ever wear the TAG so I,m not going to buy another watch even though id like too.
abmunro
Postby GeoffSmith » Sat 23.06.2012, 18:33
tigerdog wrote:Shees! Now I know why I stopped wearing a watch.
I never replaced my watch battery many many years ago. If I'm hungry, I eat. If I'm tired and the sun is not in the sky, I go to bed. If I wake up and the sun is up, I get up. It's good to be released from the shackles of the clock and a good job I work flexible hours...
Postby RayD » Sun 24.06.2012, 11:13
abmunro wrote:
RayD wrote:.
I understand what you’re saying Tony,
My sons watch never gets near water.
On the occasion of it needing a new battery we take it to Goldsmiths.
They charge £10 and point out on the receipt it’s not guaranteed to be waterproof.
I imagine they still do as good a job of sealing the back case as they would if they were carrying out a full water-proofing operation.
I always think if they let water in it wouldn’t be through the back cover.
Postby ashm » Mon 25.06.2012, 00:05
I believe some watches are also nitrogen-purged, like telescopes, which must involve some specialist kit.
My last service on my Oris was £165, and they had to replace the crown, strap and a couple of other bits - not bad value considering. I'd recommend Oris actually - seems to be about the best value "proper" watch brand, and the UK service centre do a quick turnaround.
Ad
ashm
Postby wayne » Mon 25.06.2012, 06:06
Not sure if I have been out of the UK for too long or I am a bit of a "cheap scate"
I rarely wear a watch... Although I have been tempted many times to buy a Rado. I just love the look of them :oops:
My dive comuter (and my wifes) For the last 10 yearsI have always changed the battery myself. Untill recently it was my only option here.
A local dive shop recently bought the test equipment to check them (basically a liquid filled chamber with a pump).
But at the end of the day I figure that after 10 years of cleaning and re-greasing "O" rings in the camera and no problems down to 40M or so then why pay
for someone to certify it to 200 Meters??
Unless you are a comercial diver or some kind of adrenolin freak.... then you will not be heading to several hundred meters below sea leval.
Regular usage will take you to only a few meters below sea level. As a recreational diver I have rarely exceded 60M.
Here a regular watch battery costs less than £2. So sad to see the rip off in the UK :-(
http://www.elanm100.com
wayne
Postby dapinky » Mon 25.06.2012, 15:20
wayne wrote:But at the end of the day I figure that after 10 years of cleaning and re-greasing "O" rings in the camera and no problems down to 40M or so then why pay
I fully agree with your sentiments on camera 'o' rings and my dive computer - both only get used for recreational diving - however the watch has been with me far beyond the depth that i would dare to take my olympus digital camera, or use the computer as it allows for various O2 mixes, but would laugh at me if i asked it to perform calculations involving Helium.
At 168m i want to rely on EXACTLY how long I've been there - an extra minute can add 2 hours to the decompression times :?
Return to Off Topic Area
