Service timing??
Post the Good, the Bad, and the Ugly Lotus service experiences here.
Service timing??
Postby philhecht » Mon 20.11.2006, 16:54
People - I am a servicing novice and as such, I warn you now that the following questions may cause you severe bouts of rolling around pointing and laughing. Nevertheless, I shall pursue...
How should I go about servicing the Elan?
Purchased her in July and have done 4,000 miles. It has now done 91,000.
Should it be done on a six-monthly basis or yearly basis? Or is mileage the only factor to consider?
The service schedule in the Repairs section is confusing me also - how often should I be doing an A service (it stops at 78,000)?
Is a B+C+# every 60,000 or just once at 60,000 and then no more needed.
How often should I do a C service?
Finally, is Kenny Broon still the way forward in Glasgow?
Cheers.
philhecht
Postby Gary » Mon 20.11.2006, 19:00
I reckon annually at least, but more often if mileage dictates. My specialist agrees with this
Postby Paul.P » Mon 20.11.2006, 21:47
Gary wrote: My specialist agrees with this
Ohhhhhhhhh, he's your specialist is he :gray:
Here that Dave Eds, he's Gary's specialist ! :lol:
Postby Dave Eds » Mon 20.11.2006, 21:50
He is at the moment - winter break in Cyprus on Gary eh? :lol: :lol:
Postby Gary » Tue 21.11.2006, 19:08
Bloody right. One Elan being done this week, and the other next week. You softies only take one each to him
Postby Paul.P » Tue 21.11.2006, 20:08
Gary wrote:Bloody right. One Elan being done this week, and the other next week. You softies only take one each to him
Us mere mortals, can only afford one !, not a lotus each, & an Audi each incase its raining ! :smt014
Postby Monty » Tue 21.11.2006, 21:01
But u`rs is the price of 2 :P
Postby Paul.P » Tue 21.11.2006, 21:49
Monty wrote:But u'rs is the price of 2 :P
Only done whats required me old mate, plus a little extra !
Postby Doug » Wed 22.11.2006, 03:25
how much servicing can you do on yer own :smt047
there's a maintenance/service schedule in this forum somewhere (too lazy to do the search for you) (figure Sy or John or Geoff will point you to it) and you can see the recommended intervals
your fellow Scottsmen can point you to known Lotus/Elan service places I'd expect
Re: Service timing??
Postby muley » Wed 22.11.2006, 10:05
philhecht wrote:People - I am a servicing novice and as such, I warn you now that the following questions may cause you severe bouts of rolling around pointing and laughing. Nevertheless, I shall pursue...
Cheers.
1. "How should I go about servicing the Elan?" If you are going to do it yourself, the main page has links to all the tasks. I would get the manual of the main page if I were you - it's all covered in section OE
2. Technically if you have an SE with turbo the oil and filter change should be done every 6 months or 6,000 miles. Annually should be the minimum. The specialist who serviced my blue car for the previous owner reckoned annually was OK for the SE - but the owner was consistently doing < 4,000 miles per year.
3. After 78,000 miles the manual says B at 84,000 A+C at 90,000, B at 96,000; extrapolating from this I suspect the sequence would then be A,B,A,B+C etc at 6,000 mile intervals.
4. A 'C' was due at 90,000 miles.
5. There's a good Scottish Elan clan - they'll put you right I'm sure.
FWIW my maintenance 'schedule' is; oil and filter every 6-8 months; all other fluids around 18 months. Most of the 'check/inspect' stuff is done by your MOT tester but I inspect my own disk pads from time to time..on these older cars service items get done by default in a lot of cases e.g. I renew the coolant after replacing the odd hose or radiator, replace brake fluid when I replace the hoses etc etc
Postby philhecht » Wed 22.11.2006, 10:46
Cheers lads.
Seen the Service Schedule Doug, thanks.
I can tell you now, zero servicing will be done on my own. I don't want to be responsible for any f#ck ups.
philhecht
Return to Service
