MAP sensor damper/filter
Postby Lotus54 » Fri 11.11.2011, 22:44
I was replacing all my coolant hoses and in the process managed to snap off the end of the MAP sensor damper/filter. The little screw in unit that goes on the right side of the intake manifold.
Any ideas of the replacement number or anything?
(dang I felt dumb)
Good thing, I now have all new coolant hoses, new timing belt/bearings, new drive belts, new coils/ plug wires, new coolant tank and more.
Mark
Lotus54
Re: MAP sensor damper/filter
Postby saska » Fri 11.11.2011, 23:09
Lotus54 wrote:managed to snap off the end of the MAP sensor damper/filter. The little screw in unit that goes on the right side of the intake manifold.
A100E6517S
Looks like it may be available from SJ Sportscars
Tony
adw (at) saska.co.uk
saska
Postby Lotus54 » Sat 12.11.2011, 00:32
Thanks for the info.
I'm going to see if I glue in an extension in the meantime.
Mark
Lotus54
Postby rmsmall » Sat 20.04.2013, 00:49
Being stupid, I have had to find out if one is on this side of the pond. Dave Bean has it for $30 plus shipping. It's only 11 pounds on your side at SJ but I think I will get it quicker from DB.
My daughters let me drive once in a while!
rmsmall
