IAC location
IAC location
Postby a5gcd » Tue 10.04.2007, 20:47
I am trying to find the IAC, I have looked in the manuals so I know where it is but I still can't recognise it. Has any one got a picture of the engine showing it?
Geoff
a5gcd
Postby Candles » Tue 10.04.2007, 21:10
Oh it is a total ba$tard. Still, with a bit of patience you can undo both screws and get it out without taking the engine out or any other major assembly!
I sadly haven't got a piccy, but can advise you to disconnect the intake hose, move the coolant header tank and then reach in by feel. You'll need a stubby screwdriver to get to the screwheads as well.
Sorry I can't provide the pic! I took one but all you can see are ignition cables.
Candles.
Candles
Postby ratman » Thu 10.05.2007, 10:38
sorry for the question, but..... why do you want to dismantle it??
Lotus Elan S2 n°538
ratman
Postby a5gcd » Thu 10.05.2007, 14:33
I have an occasional "stalling under steering load" problem, I just want to eliminate it from my investigations.
a5gcd
Postby ratman » Thu 10.05.2007, 14:53
that sound good... because I have the same problem.... don't forget to tell me the solution!!! :-D
Lotus Elan S2 n°538
ratman
Postby Oliver » Thu 10.05.2007, 18:15
Once you`ve removed it, don`t force the pintle, it can be reset by gently rocking it back and forth as you push it back into the IAC body. Don`t get loads of solvent near the body either, it`s a precision stepper motor.
You`ll probably tear the paper gasket when you remove it.
I replaced mine - same syptom as you describe. No improvement in my case, hope you have more luck.
Oliver
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
Postby lotuska » Thu 10.05.2007, 19:31
Paper gasket....what paper gasket? Mine only had an o-ring.
Anyway some pictures for you all.
IAC removed from manifold
IAC location on head (off car)
IAC location in engine bay
lotuska
Re: IAC location
Postby dig » Thu 26.11.2020, 20:38
Thank you for the pictures
dig
