Cambelt change and water pump
Postby Benmac » Wed 30.01.2008, 17:32
My cam belt needs doing in April so I'm starting to read up on the ins and outs on the various threads here.
The car has done 106k miles and last had it done at 82k which in April will be five years ago hence the requirement.
Now, in the history file I have there is no mention of the waterpump ever being changed on the two occasions the belt has been done. Would I be right in thinking that despite the additional cost it would be sensible to swap the pump at the same time?
I notice from the other threads that bits can be had cheaply from Rock Autos in the states. Is the saving worth it in erms of delivery reliability, parts quality and accuracy over buying more expensivey from the usual suspects here. I presume I'd need the belt, the pump and the pulleys.
Frost Silver Elan SE
Starlight Black S2 Exige 240Cup
Benmac
Re: Cambelt change and water pump
Postby theelanman » Wed 30.01.2008, 17:57
Benmac wrote:My cam belt needs doing in April so I'm starting to read up on the ins and outs on the various threads here.
ben
absolutely....and......absolutely
change the water pump...its cheap enough
get the stuff from rock autos.....cost me £160 for everything (incl postage...which took 3 days to get to me and no customs bill either)....
belt, idler bits, pump, gaskets everything.....
theyre about £50 an item from the lotus dealers.....well it all came to about £250~£260 if Id have bought here
and you should ask to see if anyone has the current discount code....another 5% off :-)))))
cheers
g
Postby Specky » Wed 30.01.2008, 19:21
Whist the coolants drained, throw in a new thermostat as well...
All the rockauto stuff fits and works...
I used Gareths list
Customs have got me on one of three packages..19 quid..
Specky wrote:
Have a discount on me...
Thank you for being a www.RockAuto.com customer! To show our
appreciation, we have a special discount for you.
Your discount code is:
868702767772
Here's how to use it:
* Enter your code in the "How did you hear about us" line of the
shopping cart.
* If you are using our traditional HTML catalog, please click the
"Set" button to the right of the field.
* Your discount will automatically appear, subtracted from your order
total.
**NOTE: We sometimes get calls from people who put the word "discount"
in front of their code and do not get the discount. Please enter ONLY
the discount code, no other words or numbers.**
The discount takes 5% off our already-low prices, and there's no limit
on order size or the number of orders. Use the code for your next
order, and share the code with friends, neighbors, relatives, the guy at
the corner garage--anyone you know who works on cars or trucks.
This discount code expires on February 19, 2008; so don't wait!
REMEMBER THE WIKI!
Postby L.G. » Thu 31.01.2008, 00:20
Does anyone know Isuzu part numbers for water pump, tensioner and idler?
Thanks,
L.G.
'95 S2 driver #286
L.G.
Postby Specky » Thu 31.01.2008, 00:37
Yep...
Clicky
theelanman wrote:
Engine : Timing Belt
GATES Part # T169 {Automotive Timing Belt 1" x 50 3/32" (159 Teeth)}
Interference engine application $17.14
Cooling System : Water Pump
BECK/ARNLEY Part # 1312115 $47.79
Cooling System : Water Pump Gasket
BECK/ARNLEY Part # 0394100
Water Pump Gasket, 1 Per Car $2.00
Engine : Timing Idler
GATES Part # T42001 {Timing Belt Pulley Steel Smooth (60mm x 10.4mm x 31mm)} $48.79
Engine : Timing Belt Tensioner
GATES Part # T41027 {Timing Belt Tensioner Steel Smooth (60mm x 10.5mm x 30.5mm)} $52.79
see here.... http://www.lotuselancentral.com/forum/v ... 4&start=20
by the way if you get the water pump you get a gasket with it....hey but for the sake of $2 I'd rather have one than not......
took rosk autos 4 days to get the parts to me...and they took paypal
Postby rip » Thu 31.01.2008, 09:48
I found the core charges a bit steep. I got invoiced by Fedex too. It still worked out loads cheaper than buying from a UK supplier though.
I have also been told by a very reputable source that most of these US alternatives look better quality than the Lotus originals.
Jack.
Postby Specky » Thu 31.01.2008, 11:10
rip wrote:I have also been told by a very reputable source that most of these US alternatives look better quality than the Lotus originals.
Jack.
What RIP said...
more pics HERE if you follow the initial links...
Postby Specky » Thu 31.01.2008, 16:47
Here's my latest discount code...
912479807929
shopping cart.
total.
This discount code expires on April 1, 2008; so don't wait!
REMEMBER THE WIKI!
Postby L.G. » Fri 01.02.2008, 01:40
Specky,
I meant something like this:
Timing Belt:
Isuzu 894429-4860 - 1" x 50 3/32" (159 Teeth)
I found someone who imports isuzu parts. I want to check if he can get me the parts but he wants to see the parts. That isn't possible so part number would be a good start I thought... I will take the gates and acdelco numbers with me then.
Thanks,
L.G.
'95 S2 driver #286
L.G.
Postby theelanman » Fri 01.02.2008, 01:57
L.G. wrote:Specky,
Timing Belt:
Thanks,
L.G.
looks like the same part to me :lol:
Postby L.G. » Fri 01.02.2008, 23:54
Oh whatever... :-D
I couldn't find them anyway, rockauto will earn some more money in the coming days.
'95 S2 driver #286
L.G.
Postby drasicjazz » Sun 02.03.2008, 05:27
BECK/ARNLEY Part # 1312115 $47.79......................
Looks like there is a wholesaler Closeout $25.79 :lol:
only 12 remaining.... 30 day warranty
TAKE it? or leave it?
thoughts?
drasicjazz
Postby drasicjazz » Mon 10.03.2008, 05:17
looking for a rockautodiscount????
http://www.retailmenot.com/view/rockauto.com
have you're pick....
drasicjazz
Postby clemo » Mon 10.03.2008, 20:08
got my stuff through in 4 days.
and the items were from 3 different shipment area's..
clemo
Cambelt change
Postby daver27 » Fri 14.03.2008, 23:51
When I change a cambelt, I mark the belt to each pulley with a paint pen and then transfer the markings onto the new belt from the old, remembering that they have to be on the same side of the belt.
Then I just matchup the marks and voila... no timing, referencing etc. needed.
If you are worried about the valves touching the pistons, just turn the motor until the pistons are half way down.
Good luck with the change.
-Dave
daver27
Postby lotusgirlmarie » Sun 16.03.2008, 02:11
Funny I do the exact same thing..... I mark mine with "white out" though. 8)
lotusgirlmarie
Goddess
Re: Cambelt change
Postby theelanman » Sun 16.03.2008, 03:03
daver27 wrote:When I change a cambelt, I mark the belt to each pulley with a paint pen and then transfer the markings onto the new belt from the old, remembering that they have to be on the same side of the belt.
-Dave
a cunning stunt.........gotta be similar all round
did the same with the cams on the rear wishbones.....
markd em, lined em up...no traking issues
gotta be the easy way to go when replacing anything :-D :-D :-D
no matter what you do.... :-D :-D :-D :-D
Postby Oliver » Tue 25.03.2008, 19:22
I have completed my parts collection for doing my cambelt. The final item i needed was a water pump, and after paying the eye watering Lotus main dealer prices for the belt and pulleys, i thought i would break my own unwritten rule and fit a `pattern` water pump, based mainly on the fact that RockAuto sell a Beck Arnley item for $25! (old stock). Even with the $80 carriage, this is about 1/3 of the Lotus price and as it turned out, quicker to supply as well - three days. (After all, it`s only coming from Texas, not Norfolk!)
I would like to keep my business with Lotus Cars, and will do where possible, but this is just ridiculous. In summary, RockAuto are the business. Oh, and thanks for the part number chaps.
Oliver
PS If it leaks / fails, i`ll take all of this back !!
M100 N/A - No PAS
RenautSport Megane 275 Cup
MGF
Benelli 2C
Oliver
Postby dapinky » Tue 25.03.2008, 21:34
Well, Oliver -
You'll be pleased to know that you haven't bought a Pattern part at all - the Rockauto ones are Isuzu OE, therefore also Lotus OE, the only difference is in the packaging (and price tag!).
That's one of the reasons we all bought 'em :-D
Postby Specky » Wed 26.03.2008, 15:14
What Dave said...
