problem knowing or finding the map sensor
Postby dapinky » Wed 11.06.2008, 19:15
GeoffSmith wrote:He'll be lucky to get a tanner and you a bob. :lol:
Must be getting old - i had to explain to Angie what the coloquial term for a 6d was :roll:
map sensor, cts sensor, hall effect sensor
Postby rushing » Wed 11.06.2008, 20:41
is there write up of replacing these sensors. or do i need a garage to this .
thanks guys again
rushing
Postby Sy V » Thu 12.06.2008, 07:20
Jason
I haven't checked but I'd be amazed if there isn't something in the Manuals... and looking at Pinky's third photo of the MAP sensor it's just a case of disconnecting the plug, and undoing the two screws mounted vertically on each end of the supporting bracket. Removing the sensor and replacing it, tightening the screws and re-attaching the plug.
Instructions for the Hall effect sensor come with it.
Postby GeoffSmith » Thu 12.06.2008, 08:17
Sy V wrote:Instructions for the Hall effect sensor come with it.
And there are some more pictures of the CAS/HES repair here. Once you've got the CAS off, it is easy to get to the CTS as well.
MAP sensor
Postby rushing » Thu 12.06.2008, 20:42
Thanks Sy . i think im going to have a go at doing the MAP and CTS myself. dont know how didfiicult the HAll sensor will be
rushing
Sensors
Postby rushing » Thu 12.06.2008, 20:48
My MAP sensor and CTS sensors arrived today. fantastic speedy delivery i have to say. i did not even get stung by import tax.
My problem is now getting a a hall Sensor. Does rock auoto do this . tried lotus everywhere no luck.
a bit pricy at some other places . does rockauto do a separate part off the hall sensor to the lotus.
thanks
rushing
Postby GeoffSmith » Thu 12.06.2008, 21:24
I've added some help on the Wiki. If you go to the Lotus Aftersales website, you can download the parts list and the order form which can be faxed through and you can specify which Lotus garage you want to pick the hall effect device up from - they're still £20! :D
Postby Gazza » Thu 12.06.2008, 21:41
Rushing,
I got stung with import tax a week after my parts :cry: , so you have not escaped yet :lol:
Gazza
S2 Midnight Blue #660
Hayward & Scott 2.5" exhaust.
SOLD
TVR Tamora in Montreal Blue
Gazza
guess what map sensor is wrong does not fit
Postby rushing » Sat 14.06.2008, 16:01
Got the map sensor delivered from Rock auto today. but it did not fit . the mechanic said the connector plug is completly different. . the three plugs would not connect to the socket because it has three different three input frames .although the sensor overall is the same size and looks everything the same .
the new rock auto sensor reads TRANSPO MAO 11011656- US - beck arnley 1580380 . the main problem the new sensors pins does not slide in to the plug.the frame inside is different.
has anyone had this same problem
Now what do i do. i will have to return the sensor back to Rock auto. also what do i re order. do i have to get another sensor which has GM on it or do i have to get the connector plug ?? tied a copule of GM shops . no luck yet
jason
rushing
map sensor
Postby rushing » Sat 14.06.2008, 16:44
tried seraching the Gm parts list and came up with this on
www.gmpartsdirect.com
GM PART # 16040749 *
CATEGORY: Computer Control Sensors
PACK QTY: 1
CORE CHARGE: $0.00
GM LIST: $0.00
OUR PRICE: $0.00
DESCRIPTION: NO STOCK LEFT ON 16040749 ORDER NEW PART #12223861
This is the first design map sensor for 1989 turbo t/a's.
This part number has changed to the 2nd design and will require using a new connector 15305891 when replacing the first design sensor with the new 2nd design map sensor
If you are installing this on a vehicle other than a 1989 turbo T/A there will not be a warranty on this part.
This is an electrical part which is not returnable per our site policies.
This old part number will be sent until stock is exhausted. Once stock is exhausted the new part number 12223861 will be sent in its place.
so does this mean i need to get a connector . does anyone know if these connectors come with the wires for easy welding
rushing
Postby Enright » Sun 15.06.2008, 18:27
rushing wrote:I bought a map sensor from Rock auto. The Beck /an;ey one from rock auto with part number 1580380. the thing did not fit the plug housing as the actuial map got upgraded .
does any one know where i can get a connector for the beck arnley.
I've deleted the duplicate thread - let's try to keep the problems/answers all in one place.
Postby GeoffSmith » Sun 15.06.2008, 20:49
Am I reading this correctly? You bought a Beck Arnley 1580380 from RockAuto and it doesn't fit? I know the Wiki listed this item (taken straight off the RockAuto listing) but RockAuto do not now list this part. :smt017
Could you confirm what you ordered and what you received and if possible post a picture?
map sensor
Postby rushing » Mon 16.06.2008, 07:46
i orderd the beck / arnley map sensor 1580380 . this is a one bar map sensor. having researched half a day on the web found out that this only fits non turbo cars. mine is a turbo with different connector fittings .
found out also that the AS4 and adelco 2 bar map sensor is a real posiibilty of the correct one .
any thoughts
rushing
Postby rip » Mon 16.06.2008, 22:16
:oops:
The turbo raises MAP to above 1 bar. That's its job.
Hello
Postby rushing » Wed 18.06.2008, 15:59
what do you mean? the as4 is i think the right one. the one i ordered def is not as it does not even fit .
rushing
Postby lotusgirlmarie » Wed 18.06.2008, 18:33
stock range map sensor
http://store.summitracing.com/partdetai ... toview=sku
Forgive summit but they have the same figures for both the 2 and 3 bar in their specs. this is in fact the correct range sensor.
lotusgirlmarie
Goddess
