Backfire
Re: Backfire
Postby Brit-Car-Nut » Tue 27.06.2017, 13:32
Danevansgolf wrote:Then realising that it wasn't the engine light coming on, it's the warning light flashing on then off when deaccellarating/ braking.
Is the light on the extreme left side ("Low Screen Wash tell tale) or mostly to the right (Brakes tell tale)?
click for full size
Re: Backfire
Postby Danevansgolf » Tue 27.06.2017, 15:39
Will check brake fluid levels.
RESET ECU. Just disconnect battery I suppose??
Will get the angle grinder out and make some new tools.
Danevansgolf
Re: Backfire
Postby Simon_P » Tue 27.06.2017, 21:52
Danevansgolf wrote:RESET ECU. Just disconnect battery I suppose??
Yes, but to do a proper job...
1. set base timing
2. Set tickover
3. reset ecu
Back to your original question backfiring on the overrun is a lean mixture, you may just have to live with it in order to pass the MOT.
Poor fuel economy is usually due to a heavy right door ;) - Or as BCN says rich mixture and backfiring can be caused by CTS Coolant Temperature Sensor - Check with elanscan
Re: Backfire
Postby rip » Sun 02.07.2017, 23:10
Simon_P wrote:Poor fuel economy is usually due to a heavy right door ;)
Predictive text cock-up?
Re: Backfire
Postby Simon_P » Mon 03.07.2017, 00:28
No humour, or at least an attempt at humour, clearly wasted - See first post.
Re: Backfire
Postby jgbff7 » Sun 15.06.2025, 09:47
I have come across this very old thread which applies to my car. Popping on the overrun.
I think it has a replacement exhaust which may be the cause.
I would be grateful for advice taking into account two facts. First the MOT man says the emissions are exceptionally good. Secondly, the popping is worse in reverse.
Are these facsts significant please?
M100 754/800
1991 SE
1992 Marcos Martina
jgbff7
Re: Backfire
Postby Tuga2112 » Mon 16.06.2025, 09:58
jgbff7 wrote:Secondly, the popping is worse in reverse.
just out of curiosity.
if the poping worse if you try to start from second instead of 1st gear ?
the reverse torque multiplyer is not equivalent to 1st but in the opposite direction. its actually somewhere between 1st and 2nd gear which demands differnet strain on the engine..
i may be leading nowhere with it. but its something that may be relevant ?
Re: Backfire
Postby jgbff7 » Mon 16.06.2025, 12:03
Thank you. I do not know but will test tomorrow. I do not usually pull away in 2nd but will report back.
J
M100 754/800
1991 SE
1992 Marcos Martina
jgbff7
Re: Backfire
Postby jgbff7 » Tue 17.06.2025, 11:52
No popping pulling away in second.
Seems to be confined to overrun and reverse. It even stalls in reverse. At least my dog knows I have arrived home.
J
M100 754/800
1991 SE
1992 Marcos Martina
jgbff7
Re: Backfire
Postby donsladek » Tue 17.06.2025, 15:37
Problems due to engine torque - loose ground, wires pulled, hoses loose or cracked??
Don Sladek
Calypso Red '91 #37594
donsladek
Re: Backfire
Postby Tuga2112 » Wed 18.06.2025, 08:15
Simon_P wrote:Yes, but to do a proper job...
1. set base timing
2. Set tickover
3. reset ecu
did you try checking the things Simon pointed out ?
